post #1 of Old 04-09-2010, 09:33 AM Thread Starter
base shakers
hood louvers
so the underhood temps in my jeep are getting too high, and i've been roasting components. i'm looking to add hood louvers. the biggest issue is that i run without a windshield a lot on the trail, and i really don't want louvers that direct the underhood heat directly at my face! can anyone recommend a hood louver where i won't have this issue?
'05 LJ, 3"+ lift, 1.25" BL + MML, 35X12.5 Toyo M/Ts on 16" beadlocks, HPD44 and HPD60, 4-speed Atlas
base shakers is offline
post #2 of Old 04-09-2010, 09:45 AM
ZachAttack923
i do not have hood louver my self but as an idea
-place the louvers on the sides of the hood so that the heat is ejected out the sides and away from you.
-also doing a radiator flush and putting in fresh fluid will bring your radiator back to peak performance and help bring temps down. also along the radiator train of though you can swap in an aluminum radiator if you can afford one.
-get the 7 blade HD fan from the stealership
-swap in an electric fan
hopefully that you can find a solution that will get your under hood temps go down and not have hot air dumping on your face
2.5L Low Output #923
White Jeep Club #923
1997 Jeep Wrangler 2.5L AX-5 D30/35 4.10 gears
31in Wildcat A/T's
Originally Posted by j_niko View Post
I would be as nervous as a virgin on prom night if I had to drive that
ZachAttack923 is offline
post #3 of Old 04-09-2010, 10:08 AM
kswyg001
2010 JK Wrangler
some guy with a YJ sawpped volvo vents to the side of his hood and he said they work well and look decent too. he's on the forum here somewhere.
kswyg001 is offline
post #4 of Old 04-09-2010, 10:31 AM
lumpster
lumpster's Avatar
-place the louvers on the sides of the hood so that the heat is ejected out the sides and away from you. Oman4x4 did a writeup about placement of the vents, top was best from what he gathered, its all on his website
-also doing a radiator flush and putting in fresh fluid will bring your radiator back to peak performance and help bring temps down. backflush the heater core while you at it also along the radiator train of though you can swap in an aluminum radiator if you can afford one. They come with an aluminum radiator from the factory
-get the 7 blade HD fan from the stealership I heard they discontinued them, may want to look into it
-swap in an electric fan Will only raise temp
hopefully that you can find a solution that will get your under hood temps go down and not have hot air dumping on your face how is hot air dumping on your face without turning on the heater?
a few changes
lumpster is offline
post #5 of Old 04-09-2010, 10:36 AM Thread Starter
base shakers
i was assuming the top would be best, but i was hoping to find louvers that don't direct the heat straight back
i just flushed the whole system, engine temps are not the problem
the electric helped with slow speed engine overheating
it could dump heat in my face as i generally wheel without a windshield, and if the vents are near the back of the hood on top the heat could come right at me
post #6 of Old 04-09-2010, 01:49 PM
BlueFlame
BlueFlame's Avatar
You could get these (Attwood louvers for example, quite inexpensive)
and put them on the sides.
Top may be better, but this is still far better than none.
Or maybe put them on the top of the hood but as far to the side as you can.
BlueFlame is offline
post #7 of Old 04-09-2010, 05:50 PM
PhulesAu
look at some place like west marine too, small panels for engine compartments.
PhulesAu is offline
post #8 of Old 04-09-2010, 05:54 PM
Hussler
1992 XJ Cherokee
Haha marine pieces? Hey they look good and work I guess
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #9 of Old 04-09-2010, 06:44 PM
Mediarocker
1993 XJ Cherokee
You could try cutting a hole in the fender behind the flare and put some louvers there.. being near the firewall the fan will push the heat out.
Help JF anyway you can. Click Here.
Threadkillers - Making Posts So Epic, They Destroy Threads
Anything will fit with IMAGINAAAAAAAAAAAATION!........and a Sawzall!!!
Currently Jeepless against my own will.
Mediarocker is offline
post #10 of Old 04-09-2010, 11:16 PM
tshively
If you put louvers in and want air flow try a 11 blade (plastic) fan out of a Ford ranger. I used the clutch as well it is off of a 2001 model year and it is approx. 1/2" shorter so it gives me a little more room with a thicker aftermarket 3 row aluminum radiator. I have yet to run it but the test fit this last winter looked like it would work. The flex-a-lite that I have now works good in cool weather but I am afraid that when summer gets here it will not pull enough air through the 3-row radiator??
tshively is offline
post #11 of Old 04-10-2010, 02:37 AM
Mediarocker
1993 XJ Cherokee
You sure you need a 3 row? Seems a little over kill if you get a good quality radiator..
post #12 of Old 04-10-2010, 05:36 AM
tjdriver
i have a hood louvre panel on my heep from a2z fab. awesome panel and works great on the trail and around town. i dunno if i'm allowed to post pics or not but i'll try.
tjdriver is offline
post #13 of Old 04-10-2010, 05:56 AM
Alkaline
Just triple core and be done with it, why waste time with louvers. And if a triple core radiator with the stock fan isnt enough, you have other issues you need to address.
☠ ʎɐqə ɯoɹɟ pɹɐoqʎəʞ ɐ ʎnq ı əɯıʇ ʇsɐl əɥʇ sı sıɥʇ ☠
'98 TJ (toy), '91 XJ Briarwood(DD)
Alkaline is offline
post #14 of Old 04-10-2010, 06:55 AM
never monday
since you have an electric fan. Consider having a switch that reverses the polarity to the motor. Then when your stopped of crawling. You can blow the heat out of the front.
never monday is offline
post #15 of Old 04-10-2010, 06:56 AM
lumpster
lumpster's Avatar
its not the engine that is overheating, read his original post. He is cooking other components, so its underhood temps that he is worried about, not the radiators ability to take care of the engine heat.
lumpster is offline
Are hood louvers and heat reduction hoods just cosmetic? TJoshX TJ Wrangler Technical Forum 31 01-13-2010 08:29 PM
Real Cheap Hood Louvers offroad91yj YJ Wrangler Technical Forum 7 07-04-2009 10:02 AM
Hood Louvers Anyone? DARKBLUETJ TJ Wrangler Technical Forum 9 03-11-2009 06:58 PM
Hood Louvers ThUmPeRcOn TJ Wrangler Technical Forum 30 07-07-2008 10:45 AM
Gen-Right Hood Louvers Linda or Greg TJ Wrangler Technical Forum 6 10-06-2006 07:29 AM
You may not post new threads
You may not post replies
