Homemade Swaybar Disconnects (4x4xplor)
| Poison Spyder BFH Rear Bumpers | Front and rear Drive shafts @ free shipping | Poison Spyder February Special: FREE Rubber Liners when yo |
#1 | ||
Anybody run the ones on 4x4xplor's website? Comments, opinions would be greatly appreciated.
http://4x4xplor.com/homediscos.html
Green Jeep Club Member #183 |
#2 |
Buy my home made ones
![]() http://www.jeepforum.com/forum/showthread.php?t=596948 I made my first set similar to those and they worked, then went with the ones I listed above. Now I bought a lift kit and some were included with it so I am running those. |
#3 | |
I run the exact set listed on the site. I bought what was listed and it works perfectly...no problems yet. I actually bought about 3 or 4 clevis pins and extra washers and cotter pins to keep in my toolbox just in case....I still think I only spent $10-$12 at the hardware store. |
#4 |
Roughin' it smoothly
I made a set of the disconnects, but the are very noisy while on road. Mine stay disco'd full time now. I got tired of hearing them.
Christian Jeepers _ Member #2 United Four Wheel Drive Association _ Member National Rifle Association _ Member |
#5 | ||
#6 |
I have never heard mine at all. I am running an '01 TJ Sport and bought the exact sizes listed in the write up. Mine is a daily driver as well.
#7 |
I took mine off two weeks ago when I installed the FT 3" lift because the lift package came with a set.
After 11 months of using the homemade set there wasn't any real wear, although one of the big washers bent a little due to my misaligned sway bar. They weren't noisy at all. The FT quick discos are a big improvement. I can actually manipulate them by hand - the homemade ones I needed a pair of pliers to get the pins in and out. ![]() Not a bad experience for less than ten bucks. I wouldn't run them on a permanent basis but it was a good placeholder until the real set came in.
The top and doors on this vehicle are designed only for protection against the elements. Do not rely on the top and doors to contain occupants within the vehicle or to protect against injury during an accident. Wear seatbelts at all times. |
#8 |
Thanks tjsahara1979 for asking about this. I'm doing this mod this weekend and its always good to hear everyone elses reviews first.
2000 Wrangler SE: Old Cobra 19 CB 31x10.5 MTZ on 15" Procomp steelies Cotter pin disco'd So there I was with a JEEP fund, and then the baby ate it all! |
#9 | ||
I just had to make sure
#10 |
They inevitably egg out the holes on the axle bracket a little bit although once you get real ones where the lower link bolts on, its a moot issue. It's a very sh!t solution though.
'94 YJ - 34x10.5 Super Swaper LTB "pizza cutters", 2.5L/AX5/231, D30/8.8 4.88, 63mm throttle body and manifold, electric fan, Dynomax exhaust, SYE/CV, SOA on stock springs, MORE traction bar, Teraflex tummy tuck, Milemarker 9500 hydraulic winch, various skids '06 LJ Rubicon - 31" Trxus, OME 2.5", belly up, various skids '75 CJ5 basketcase brewcitycrawlers.com |
#11 |
rattle like crazy
#12 | |
Thanks for all of the info!
Anybody else want to comment?
#13 | |
#14 |
I ran them for 2 years also---no problems. I did weld the washer to the head of the clevis pin just to be on the safe side.
#15 |
SolidMember
Mine rattled like a bytch, and we're a PITA to get off/on, even on level ground. I just broke down and bought some JKS Quicker Discos, which are 1,000 times easier to deal with. A case of getting what you pay for IMHO. Sure, you can make them for 10.00, but it was almost easier just removing the end link bolt and reattaching it when done wheelin for me until I got my discos.
2010 JK Wrangler. Born to me on 12/28/09 when El Jeepo (TJ) decided 160K was enough, and threw a rod through a cylinder. BUILD: Rubi Rocker Guards; 32" Mastercraft MTs; Teraflex 2.5" Coil Spring Lift; JKS Quick Discos; JKS Front & Rear Adj Trackbars; JKS Ex Rear Swaybar links; Zone Nitro Shocks; 1.5" Rough Country Wheel Spacers; Poison Spyder Evap Skid; Cobra 75WXST; 3' Firestick quick disco; Rugged Ridge XHD Fr Bumper; Tuffy Underseat Drawer; 6" KC Long Range Hilites; Superchips Flashpaq, Crown Extended brake lines WISH LIST: Front LCAs, Winch, 6" KC Driving Lights, Deep Cycle Battery |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
