Homemade Skid Plate - JeepForum.com
post #1 of 4 Old 07-19-2007, 06:46 PM Thread Starter
jake7893
Homemade Skid Plate
I'm trying to make a home made skid plate. I've seen people with them on before, and I thought I'd make one. I want one towards the front of my Jeep in front of my stock one. I tried mounting it yesterday, but there is nothing to mount it to. I don't want to weld anything to my frame. I was just wondering if you guys have done this or mounted anything like that. I was going to take the 2 bottom bolts out of my transmission and make brackets there, but that doesn't seem like a great idea. Any suggestions would be greatly appreciated.
WARNING**
ALL RESPONSES BY THIS USER ARE KNOWN TO CAUSE CANCER (ONLY BY THE STATE OF CALIFORNIA)
WARNING**
jake7893 is offline
post #2 of 4 Old 07-19-2007, 07:08 PM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
Check out the mounting design at www.skidplates.com on Skid Row stuff.
2009 JK Rubicon (Former Daily Driver); 2014 VW Jetta GLI Autobahn w NAV.
Auto, Power, Remote Start, Towing Package, MyGig Navigation with Lockpick, Rear View Camera, B&M 70268 Transmission Cooler, Aeroforce Interceptor, Valentine 1, Tub Sound-Deadened with Raamat and Ensolite, Hard Top Heat Insulated with 1/2" Styrofoam Insulation, Bilstein Shocks Front & Rear, PIAA Dual Horns, IPF 920H4 Headlights.
Protection: Skid Row Engine Skid, Lower Control Arm skid & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Differential Skid Front & Rear.
Recovery Gear: Warn 9.5Ti Winch, 11,000# Pull-Pal.
Communication: Uniden 520XL CB, Diesel External Speaker, 3' FireStik Whip.
Shrockworks Mid-width Front Bumper with Warn 9.5Ti Winch -- Ordered 7/17/2009; Bumper Received 12/4/2009.
1" Coil Spacer Front & 1/2" Coil Spacer Rear restored OEM Rake.
4x4 Trips:
Moab - 4/2006, 5/2008, 4/2009, 5/2011, 4/2013
Ouray - 8/2007
Rubicon - 9/2008
Gone, but not forgotten: 2004 TJ, 1999 Audi A4, 1992 VW Jetta GL 5 Speed
Thunderstrike is offline
post #3 of 4 Old 07-19-2007, 07:23 PM
BYuen
BYuen's Avatar
I wish I had the mechanical creativity to create my own heavy duty skids. That would be cool. Or even if I knew how to weld...
BYuen is offline
post #4 of 4 Old 07-19-2007, 08:31 PM
hatch524
My engine skid is by 4 Wheelers Supply.
See: http://www.4wheelers.com/jeep-tj-oil...63-p-1116.html
The photo in the link doesn't show the mounting points but the rear mounts to any flat crossmember (ie the RE long arm flat belly pan). It is kind of hard to describe where the front mounts... There are some factory holes (I think three) in the side of the box attached to the frame the motor mount bolts to. 4WS fabs a L shaped bracket with three studs welded to it that fits into the three holes on the motor mount support. A U shaped 3/16 support cradles the engine bolting to the skid at the bottom and the motor mount boxes on both sides of the motor.
Skid-Rows bracket is similar. See the Skid-Row bracket and a custom skid here:
http://www.stu-offroad.com/guards/tranny/tranny-1.htm
hatch524 is offline
JP0020 Skid Row engine skid plate mmarmouz TJ Wrangler Technical Forum 3 11-13-2009 10:06 AM
Skid Row Evaporative Canister Skid Plate mrsig JK Wrangler Technical Forum 6 01-26-2009 07:46 AM
Anyone run a Muffler skid plate? A skid plate like the Kilby? JK Zombie Butt JK Wrangler Technical Forum 1 09-04-2007 02:51 PM
Homemade gas tank skid... mferrari TJ Wrangler Technical Forum 10 06-21-2007 12:40 PM
Homemade SKid Plate yarosig YJ Wrangler Technical Forum 14 12-07-2006 11:14 AM
