Homemade Quick Discos - JeepForum.com
post #1 of 2 Old 03-19-2012, 01:43 PM Thread Starter
Zjones1994
So i know this isn't anything new but I figured I'd contribute to the community for once. I saw the write up on 4x4xplor.com (http://www.4x4xplor.com/homediscos.html).
The things youl need are:
A T-55 torx bit
18mm Wrench
2 2 1/2x 7/16 Clevis pins. (My local hardware store was out so i got 3x7/16)
2 cotter pins
4 7/16 Grade 8 Washers
1. Begin by using the t-55 with a 18mm wrench on the nut to remove the bolt running through the discos.
2. If the bolt is stuck or dosnt want to come out spray with some PB or my personal choice Aero Kroil. Then beat out with a dead blow hammer.
3. Re-align the sway bars and with a clevis a washer on each end.
4. Place the cotter pin as close to the sway bar end as possible.
5. Go hit the trails and enjoy.
1998 Chili Pepper Red Jeep
USN Hull #233
Check out my build!
Zjones1994 is offline
post #2 of 2 Old 03-19-2012, 02:32 PM
pmcjeep
There are alot of write-ups about this under the cheaptricks & fixes section.
01 tj 4.0,bds springs,ROKMEN arms, ecgs 8.8 and hp30 both locked with 4.88s,35in STTs,Smittybilt bumpers,8k winch,hylined MCE flatties,TKHfab rocksliders,and lots more to come!
pmcjeep is online now
cheap , homemade , quick disconnect , sway bar
Homemade quick discos with lift? ChrisTJCO TJ Wrangler Technical Forum 1 04-27-2011 04:43 PM
Homemade Quick Discos ? deerassassin22 TJ Wrangler Technical Forum 28 02-11-2011 06:35 PM
Anyone with homemade quick discos? Redz72 TJ Wrangler Technical Forum 6 07-27-2010 04:08 PM
saw lots of reports and finally did it! (homemade quick discos) Beerman621 TJ Wrangler Technical Forum 4 03-06-2010 01:53 PM
Homemade Quick Discos matt1988 TJ Wrangler Technical Forum 31 01-13-2008 06:30 PM
