Homemade: Light bar, Rockers, Roof Rack - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Homemade: Light bar, Rockers, Roof Rack
Steering and more from Ruffstuff!Rough Country Deals at JeepHut.comThe Ruffstuff 14 Bolt Complete Swap Kit!
Unread 01-11-2007, 09:03 PM   #1
tmwoodall
I tackled a few jobs over my break from school, my favorite two were the rockers and herculiner.
I am attaching the pics of the rockers, light bar, and roof rack.
I read through several of the notorious rocker threads and came up with my design. There are a total of three sandwich plates on the inside, two on the floor and one the whole length of the tub wall.
I will be happy to answer any questions about any of it.
tmwoodall is offline   Reply With Quote
Unread 01-11-2007, 09:13 PM   #2
NJRIwrangler01
wow, they look awesome! Can we get some closer up shots, how did you attach the roofrack to the truck, weld it on?
2006 Wrangler X - Stock for now-Tow Strap- K&N CAI (came with purchase)
Front: D30 Rear D35 3.07 gears
Olympic front and rear bumpers/Tow Rack
NJRIwrangler01 is offline   Reply With Quote
Unread 01-11-2007, 09:17 PM   #3
tmwoodall
I will get some better shots tomorrow, I used the windshield bracket wholes on the front and drilled three holes on the back, and put a sandwich plate inside the wheel wheels and pop riveted that in place to make it easier to take on and off if need be. Then I used those trailer type pins with the d loop that is attatched and clips over the pin for easy swing out of the front to back braces, so the arms can swing out quickly the soft top is fully functional with my rack
Unread 01-12-2007, 02:32 AM   #4
EaglesSJ
Looks great. It always feels good to get something like that accomplished.
THE "ZOMBIE SLAYER" BUILD THREAD
http://www.jeepforum.com/forum/f22/b...slayer-974742/
_______________________
http://www.biteforce.net
EaglesSJ is offline   Reply With Quote
Unread 01-12-2007, 06:26 AM   #5
keoki04
Nice job!!! Wish I had the time to do things like that...
Current Ride:
97 TJ Sport 5spd
Check profile to see the mods!
Other mods to come...
My crazy dog!
Clicky You've gotta love days like this at work! Yes, I threw it...Clicky
keoki04 is offline   Reply With Quote
Unread 01-12-2007, 07:58 AM   #6
Sbeltinc
Nice work!
Can you share pics of the underside of your rockers? I'm planning to make a set and am exploring the possibilities.
Thks
Sbeltinc is offline   Reply With Quote
Unread 01-12-2007, 08:59 AM   #7
jeepntexas
Yeah very interested in your rockers. I am planning on building a set in the spring. I would like to see pics of yours up close.
Your mods look very cool.
2005 Silver Sport (Stock)
2002 Black Sahara [B]SOLD[/B] Stupid me!!!
[COLOR="Yellow"][B]Ravines for Sale[/B][/COLOR]
jeepntexas is offline   Reply With Quote
Unread 01-12-2007, 09:02 AM   #8
tmwoodall
Sure thing I am going to get some better pictures up in about an hour. The underside was the 3" leg of the 3x5x1/4. About a third of the way from the front you have to cut out about an inch and a half due to a dropped portion of the tub. Then the rest needs a 1" spacer I used 1" square tubing. My sandwich plate goes through that tubing. Pics to come early afternoon
Unread 01-12-2007, 11:21 AM   #9
tmwoodall
When it is dry outside I will crawl under there and get you a better shot of the underside, but as the pics show it is raining here right now. My computer crashed so I lost all but a few shots of me welding during the build process, I am pretty bummed I can't show the step by step, I had some great shots of the stages.
Unread 01-12-2007, 12:01 PM   #10
Sbeltinc
Thks for sharing.
Unread 01-12-2007, 02:28 PM   #11
Patriot
Nice work.
'03 TJ
Blue Jeep Club Member #58
Patriot is offline   Reply With Quote
Unread 01-12-2007, 04:26 PM   #12
bigchevyman24
One thing about the rockers is you should turn the bolts around so the head is outside...that is if you ever go on rocks...you will bend the bolts or stick on them with them sticking down like that...put the head on the outside so it will still "slide"...my .02 but it does look great and is definately strong...good job!!!
CURRENT: 2001 WJ V8 LIMITED - Quadratrac, 60th anniversary, Fat Bob's 2.5/2 lift, HID's, roof rack, 31" Rugged Terrains, 5k lb Curt Hitch
SOLD: 2000 WJ 2WD CONVERTED TO 4X4, 97 TJ ON 35'S, 95 XJ ON 33'S
bigchevyman24 is offline   Reply With Quote
Unread 01-12-2007, 04:35 PM   #13
tmwoodall
Yea I might grab some shorter bolts and do that. I went with Grade 8 on the whole rack and sliders. So it should withstand some abuse. When I get bored someday maybe I will switch those bolts out. Thanks for the tip.
