#1 | |
homebrew aluminum snorkel
i did a lot of JF research and found a lot of info on homebrew snorkels so figured to try my hand(and welder and grinder) to make my first one.
its turned out better than id hoped for also but the next time will be top of the line.not that anythings wrong with this one..all aluminum 1/8 thich material.. heres some start to finish pics.. ![]() ![]() ![]() ![]() ![]()
#2 |
after cutting and notching with a skill saw and a jig saw it started comeing together a bit..
![]() ![]() ![]() im starting to like it better than yesterdays 4 hrs of workin on it.. ![]() |
#3 |
nice work. are you going to paint it?
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#4 |
the next day i all to fit good and solid..tabs are 1x1/4 aluminum flat bar that bolt to the side brackets..its so strong i can grab it anywhere and shake the crap outta the jeep and it dosent move..i sure i could stand on it but wouldnt want to lay it on a pile of rocks to hard lol
#5 |
the tubeing inside the grill is cut short so if water enters while a down pour it will have no choice but to run out and down instead of over the tubeing where i left it a 1/2 inch higher when copeing it into the pipe.
#6 |
oh, guess i should wait to post. looks nice!
#7 |
TITS
That looks EXCELLENT. Nicely done. I wouldn't mind one....
#8 |
yes
not so bad for the first try..im happy with my 30 bucks and about 7 hrs time involved versus 400 bucks that will melt and crack someday ![]() its spray painted till i have some stuff to go to the powder coater and then it will get sand blasted and coated satin black 2 times..the paint wont last 1 trip thru some fla trees.. thanks for the flowers unlimited04,john |
#9 |
dude, in my opinion I would much rather have that than a arb or volant any day. that looks fantastic. awesome job man. I wish i had those skills
#10 |
did you use a MIG or TIG? what welder & amps do you have?
#11 |
i use a lincoln 255 on low range with a converter box to run a cheap miller 3445 spoolmate spool gun i got from sears..its welded over 150 aluminum entry gates over 5-6 yrs and has payed for itself over and over again..it is getting to the point it needs new cables and hoses soon on the spool gun but for 500 bucks or so its cheaper to get a new one since i make a liveing(slow liveing this yr)with it and dont listen to a boss ![]() |
#12 |
I think you should make me one. Ill pay
#13 | |
then i goofed up by a 1/4 inch so thats why its in line with the fender now. if i get bored enough being retired do to economy being slow lol,haha i will move it on the fender top again and redo the mounting holes i goofed on a little the first time..the next one will be real sweet since it was a learning experience the first time. heck it really could be stood on to wash the roof but i dont think i will just yet..i could build and sell them for 400 bucks but..well you know the liability and stuff with stupid people..i could even powder coat them for that price your choice of colors..i guess ive shipped gates to all over the place it really no diffrent..just a lot less shipping hahaha. |
#14 |
Wheel Weber
Ha ha, a lot of the home made snorkels are in FL.
That looks really good, do you have any under hood shots? have you hooked it up yet? Again that looks really good |
#15 | |
im thinking of makeing my own canister or useing one from a buick i seen on another post somewhere and moveing everything to the drivers side. when its on the pass side on the holes in the lower fender its got to have 8-9 fott of crap before it gets air. ![]() on the drivers side i figured its only gonna have the snorkel and 2 ft to the intake.. ![]() just my way of thinkin but its gonna work fine im sure..not that nothins wrong with pvc pipe either..it does work.. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
