home made insta trunk? - JeepForum.com
post #1 of 13 Old 05-14-2009, 03:32 PM Thread Starter
hoot20
i really like the insta trunk and i would end up buyin one unless someone has some ideas on making something like that. i use my back seat and its always in there (unfortunately) so the area behind the back seat is all i need to cover. has anyone made something about like the insta trunk? thanks for any info!
2000 TJ sport "STORMTROOPER" dual tops, 4.0L, 2.5" coil spacer, 2" BL, jks quicker disconnects, worn out 35x12.50 bfg M/Ts, 15x8 d window rock crawlers w/ 4" backspacing, front stinger, custom rear bumper, superwinch lp8500 winch, a to z rocker guards, husky liner floor mats, CB/PA system, daylighters, and straight exhaust
Originally Posted by boone78 View Post
jeeps don't stuck, they just take breaks every once in a while, in deep holes.
Originally Posted by Prot View Post
Dirty Deeds, Done With Jeep!:duhrock:
hoot20 is offline
post #2 of 13 Old 05-14-2009, 03:42 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
lots of write up on here from guys that made them from wood, but very simple, make template from card board, trace to wood/metal, cut, bolt it on
RnEmOvr is offline
post #3 of 13 Old 05-15-2009, 09:33 AM
Faramir66103
Here's a link to the one I made, with a drawing and measurements here.
HTH,
Adam
'99 TJ Sport, 4.0 I6, 5 speed manual transmission, Hi Lift w/offroad kit, Viair 450C compressor, Garmin GPS, Skid Row Engine/Transmission, steering box & radiator skid plates, Kilby gas tank plate, AtoZ Fab full length rocker guards, Performance Accessories 1" Body Lift, OME 2.5" HD springs & shocks, JKS trackbars front & rear, BFG AT 33x12.5r15, EBC Yellow pads and Centric rotors
Faramir66103 is offline
post #4 of 13 Old 05-15-2009, 09:35 AM
cadencedad
cadencedad's Avatar
its easy just carpet a piece of thick wood and mount it level with the tub..Took about 10 minutes
cadencedad is offline
post #5 of 13 Old 05-15-2009, 11:17 AM Thread Starter
hoot20
sweet. thanks yall.
hoot20 is offline
post #6 of 13 Old 05-15-2009, 02:07 PM
Whybu1
Lets go Penguins!!!!
Whybu1's Avatar
HTH,
Adam
That isn't real secure as there is access by simply folding the rear seat.
Whybu1 is offline
post #7 of 13 Old 05-16-2009, 11:26 AM
Faramir66103
Sure, but in order to flip my rear seat you have to have access to the area under the steel plate. To get that access you have to open the (always locked) tail gate. I know that later model rear seats had release latches at the top of the seat but mine is at the bottom. I don't know what year they changed though, so perhaps this won't work for the OP.
FWIW,
Adam
post #8 of 13 Old 05-16-2009, 09:33 PM
mscottz
2011 JK Wrangler
Adam's trunk is exactly what I have in mind, but I plan to use some nice thick diamond plate.
Colorado Jeep Club member #1969
mscottz is offline
post #9 of 13 Old 05-16-2009, 09:46 PM
ScottHarr_TJ
2010 WK
I've got one i'll sell to you. its steel plating with carpet on the top. PM me if you're interested
00' TJ-sold
'10 WK
Blue Jeep Club Memeber #132?
ScottHarr_TJ is offline
post #10 of 13 Old 05-17-2009, 09:42 AM
vfrpilot
Here's a link to the one I made, with a drawing and measurements.....
Thanks Adam..
Think I may try to fab one of these up -
Any last minute pointers ??
Also, did you compensate for the rear seat belt pullys ??
08 SAHARA 3.8 Lifted
AEV, EMU, 33" NITTO GRAPPLERS
vfrpilot is offline
post #11 of 13 Old 05-17-2009, 10:03 AM
Faramir66103
vfrpilot you're quite welcome. So many folks have been helpful to me here it's nice to be able to help others.
There are three things I'd probably change if I did it again. First, I'd have the fabricator bend a lip into the front and back edges to keep it from bowing. In my original I accomplished this same goal with aluminum angle riveted along the front edge. Though it works, it rattles a bit. With the proper sheet metal brake a simple bend on each edge would be trivial. Of course these bends can't extend the full length, just along the area between the wheel wells, otherwise it won't slide under the seat belt mechanisms.
The second thing I'd change would be to make it slightly less deep, perhaps 1/8" less. As it is now, it puts pressure on the rear seat and tailgate. This has caused some paint damage on the tailgate and has rubbed a small hole where the seat cover fabric has been under pressure between the seat's frame and the steel plate.
The third thing I'd change would be to cut the notch for the tailgate latch closer. This probably has no real impact on it's security, but it wouldn't be hard to accomplish. This was one of my first DIY projects, and I've learned a lot since then.
At this point I'd mock it up out of cardboard or foamboard and then take my measurements from that to the metal fabricator. The last time, I made my measurements directly from the Jeep and then made a drawing and had the steel cut. Oh well, live and learn.
I didn't compensate for the rear seat belt mechanisms at all. The steel plate simply slides under them. There's a gap between them and the wheel well that the plate fits in pretty well.
HTH,
Adam
post #12 of 13 Old 05-17-2009, 10:26 AM
vfrpilot
vfrpilot you're quite welcome...Adam
When / if you ever have the time - it'd be great if you updated the drawing/measurements you have online - for the guys who arent pro-active enough to inquire [with you] like I did & just think they've hit gold when they come upon the link and they the pic (like I did ) - Again Adam, thanks bro - as we say; You da man !
vfrpilot is offline
post #13 of 13 Old 10-23-2009, 08:55 PM
BullandTerrier
2009 JK Wrangler
I built one out of 3/4" plywood and painted it with rustoleum black textured spray paint . I'm still in the process of bolting it down with some kind of quick release.
I'm just a girl with her dog and her ||||||
BullandTerrier is offline
Self made Insta-trunk? iceman123187 TJ Wrangler Technical Forum 21 05-18-2014 08:44 PM
need an insta trunk archer75 TJ Wrangler Technical Forum 3 10-02-2007 09:17 AM
insta trunk xl 90XJ02TJ TJ Wrangler Technical Forum 0 02-16-2003 02:53 PM
Insta-trunk, Anybody got one? battlestar YJ Wrangler Technical Forum 3 08-09-2002 06:00 PM
insta-trunk Tracker00 TJ Wrangler Technical Forum 1 01-04-2002 09:18 AM
