Home Built Swing away rear bumper - JeepForum.com
post #1 of 25 Old 11-10-2009, 10:20 AM Thread Starter
Lifted-04-LJ
I know it's been done before but I just had to share...
Total cost has been under $260 and I have steel left over for side steps and a front bumper.
King Metals
2x2x3/16-22ft $50
2x4x3/16-20ft $75
Southwestwheel.com
trailer spindle and 2" u-bolt kit total was ~$45
Home depot
grinding wheels, 3/16x1.5" strap, paint, 1/2" grade-8 bolts, washers, and nuts, safety pin, picture wire, and crimp-on ferrules. ~$50
Harbor Freight
Trailer hitch- $20
Oreilly's
Etching Primer $10
Donated material...
scraps of angle iron (personal stash)
36" of 2x3x3/16 (reinforce rear cross member)
Frame extension 2x4x3/16 - 4"
Fit the brackets
Spindle hinge with bolt flange removed
2" Hole for Spindle.
Brackets mounted and Bolted 1/2" x 3" grade 8 bolts.
Bumper mounted with hinge in place.
2004 LJ, 4.0l, Auto, 35x12.50x15 BFG MT KM2's, 4" superlift, RE SS brake lines, 4.56 Yukons, D44/Detroit Rear, D30 Front,
, Smitty Xrc10, Hi-lift extreme
Lifted-04-LJ is offline
post #2 of 25 Old 11-10-2009, 10:23 AM Thread Starter
Lifted-04-LJ
More pics...
Second of the hinge in place..
Cap the frame extensions
Cap the bumper ends..
Fit the swing arm..
post #3 of 25 Old 11-10-2009, 10:28 AM Thread Starter
Lifted-04-LJ
Weld the arm on...
Arm and brackets welded..
On the jeep to measure and place the upright for the spare tire.
post #4 of 25 Old 11-10-2009, 10:32 AM Thread Starter
Lifted-04-LJ
I didn't get pics of the making of the tire mount. I used the stock mount flange and reinforced it with a u-bolt mounting plate the welded it to 2x2x3/16 tubing then bolted it to the 2x2x3/16 vertical from the swing arm using 2" square axle u-bolts. Here is a picture before paint and a close-up after.
post #5 of 25 Old 11-10-2009, 10:39 AM
NotURMailman
NotURMailman's Avatar
Looks good. Are you adding supports to the upright (to make an "A" frame type)?
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #6 of 25 Old 11-10-2009, 10:40 AM
FlyinPhil
looks great! i plan to do one this summer as well
A 6spd makes it a race car right?
FlyinPhil is offline
post #7 of 25 Old 11-10-2009, 10:42 AM Thread Starter
Lifted-04-LJ
Latch assembly..
I used a 1/2" by 1" bolt with a washer and some rebar for a t handle.
I mounted a piece of angle to the bumper. Welded a piece of flat bar to the swing arm. Drilled a hole through the flat and the angle, put the bolt through the hole and welded the nut to the back of the angle iron. I then welded the washer with a notch in it to the bolt and drilled a hole to match the notch in the angle. I then welded a second piece of strap with a washer for a spacer to retain the bolt to the arm. I then welded 2 pieces of rebar to the bolt for a handle.
After Paint
post #8 of 25 Old 11-10-2009, 10:45 AM Thread Starter
Lifted-04-LJ
I added that before the paint. I only added one side ... from the vertical to the hinge at a 30* angle. It got rid of almost all of the flex.
post #9 of 25 Old 11-10-2009, 10:48 AM
NotURMailman
Right on! I just didn't see it in the pics...
post #10 of 25 Old 11-10-2009, 10:49 AM Thread Starter
Lifted-04-LJ
I added the hitch, reinforced the rear crossmember(2x3x3/16") and primed it...
This one shows the swing stop for the arm...
post #11 of 25 Old 11-10-2009, 10:49 AM Thread Starter
Lifted-04-LJ
Sorry about that...
post #12 of 25 Old 11-10-2009, 10:54 AM Thread Starter
Lifted-04-LJ
Here is the finished product.. Rustoleum satin black with self etching primer underneath.
Latch, safety pin, and lanyard.
Reinforced arm
The tire mount again..
post #13 of 25 Old 11-19-2009, 02:29 PM Thread Starter
Lifted-04-LJ
I had to take off the tire to work on the fron bumper.. it fits in the garage better that way. While it was off I touched up some paint.
the latch assembly..
post #14 of 25 Old 11-23-2009, 10:40 AM
ritjobbie
Do you have any pics of the cross-member reinforcement? Does it seem to be holding up okay without frame tie-ins?
1995 YJ Rio Grande, 2.5L Low Output Engine
ritjobbie is offline
post #15 of 25 Old 11-23-2009, 11:15 AM Thread Starter
Lifted-04-LJ
I added a 2x3x3/16" reinforcement between the 4" frame extensions. The frame extensions are 2x4x3/16" tubing. the bumper is bolted to the frame extensions with 4 - 1/2" grade 8 bolts and 3/16"x2" angle brackets.
The 2x3" tubing was really to tie the hitch to the frame. the welds holding the 2x4" tubing are more than enough to support the bumper and tire carrier. I figured the load of a trailer might be able to flex the bumper. I'm contemplating adding a center mount but to date there are no cracked welds.
pics...
Rear bumper with built-in rear winch mount - any advice ? harald-hans JK Wrangler Technical Forum 2 01-10-2011 02:06 PM
Anybody have the ARB Swing Out Rear Bumper? Oman Jeep TJ Wrangler Technical Forum 10 05-02-2008 04:06 PM
Rear Bumper & Swing Away - Why? nunzio JK Wrangler Technical Forum 3 11-16-2007 11:03 AM
Rear Bumper/Tire swing away chachy TJ Wrangler Technical Forum 27 08-14-2006 10:34 PM
Home Built Bumper And Tire Carrier blackyj YJ Wrangler Technical Forum 17 12-13-2002 04:43 PM
