Hole in 1997 TJ wranglers frame - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Hole in 1997 TJ wranglers frame
USA Standard Chromoly Front Axle Shaft Kits with Dana 30 4TJ 5.25" Speaker Adapters - NalinMFGStainless Steel Door Hinge Pins
Unread 04-29-2014, 02:32 PM   #1
Jeepkid315
Hey fellas, I just bought a 1997 tj wrangler and we were looking at the frame and got under the under coating and found the frame was cracked. So we started investigating and come to find it is rotted the whole way through. Anyone have any idea what I should do? It was just inspected a week or so ago. How often does remanufactured/used frame come along? an how much do they cost?
-JRRJR
Jeepkid315 is offline   Reply With Quote
Unread 04-29-2014, 02:44 PM   #2
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Welcome to the forum.
Post some pics of the frame and we can give you a better idea if it can be repaired or if a frame swap is a better alternative.
I've seen good shape, used TJ frames going for around $400-500.
Wheelin98TJ is online now   Reply With Quote
Unread 04-29-2014, 02:46 PM   #3
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
http://www.quadratec.com/products/pr...=38&b=c&sv=200
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
Looking to swap my 4" springs for your 2-3" springs. PM for details.
RnEmOvr is offline   Reply With Quote
Unread 04-30-2014, 01:05 PM   #4
Jeepkid315
I was told last night that this can be welded but I still have my doubts about it. It just keeps saying Error when I try to post the pictures.
-JRRJR
Unread 04-30-2014, 01:05 PM   #5
Jeepkid315
And I got it.
-JRRJR
Unread 04-30-2014, 01:32 PM   #6
Wheelin98TJ
JEEP FREAK
It certainly doesn't look good, but maybe just that section could be replaced/repaired.
How does the rest of the frame look?
I'm afraid a frame swap is the likely answer here.
Unread 04-30-2014, 01:50 PM   #7
Jeepkid315
The rest of the frame is fine. My dad was planning on getting someone to weld a piece of metal to the mount and run it up the bend. Would this even work.
-JRRJR
Unread 04-30-2014, 02:01 PM   #8
festerw
Davey's Jeep in Salem, OH or Simpson Family Jeeps in Meadville, PA would be sources for good used frames.
Hers - 2005 Jeep Grand Cherokee Laredo 3.7 4x4
Mine - 2003 Jeep Wrangler X
festerw is online now   Reply With Quote
Unread 04-30-2014, 02:13 PM   #9
Jeepkid315
Thanks festerw.
-JRRJR
Unread 04-30-2014, 03:22 PM   #10
RnEmOvr
RnEmOvr's Avatar
If you check the link I posted above it is for new sections you can buy and weld in.
Unread 04-30-2014, 03:23 PM   #11
darren2569
A good welder could repair it but I'm betting thats not the only bad spot. I patched mine in the same area but it wasnt near as bad as yours is. I vote frame swap.
The JK driver blonde bing-bing fingered me!!!
darren2569 is online now   Reply With Quote
