Holding flag nut...? - JeepForum.com
post #1 of 14 Old 11-04-2005, 06:16 PM Thread Starter
thejafe
thejafe's Avatar
Ok, I need to tighten my track bar on the passenger side... what's the best way to do this without BREAKING the flag nut? Seems like when I try to tighten it down the whole thing moves and the flag part just bends instead of the bolt turning inside of it. I've broken one flag nut in the past and it was a HUGE pain to replace. Don't want to experience that again. Any tips here before I put a wrench on the thing?
thejafe is offline
post #2 of 14 Old 11-04-2005, 10:01 PM
Oman Jeep
Oman Jeep's Avatar
If it bends... would vice grips help stop that?
I haven't driven mine since the flag nut arrived, 2 days before I left Oman, so I've yet to experience this fun...
Best way might be to let the dealer do it and let them face the problems if it breaks
Oman Jeep is offline
post #3 of 14 Old 11-05-2005, 12:05 AM
got4-Lo
i broke the flag off.... i jsut replced with a regular nut... i had to use an off set wrentch to get to it though, u could take a cut off wheel and notch out a little room for a wrentch
stretched *** tj
got4-Lo is offline
post #4 of 14 Old 11-05-2005, 12:58 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
It's possible (not even that difficult) to get a wrench on a non-flagged replacement nut.
Jerry Bransford is offline
post #5 of 14 Old 11-05-2005, 06:23 AM Thread Starter
thejafe
thejafe's Avatar
Yeah I've got to figure something better out then this whole flag-nut business. I have a Skid Row LCA skid on there and it makes it that much harder to access the flag.
I like the off set wrench idea. There's veryl little room in there but I'd rather have a way to get a whole wrench on a nut rather than rely on that flag. I'm not confident that thing will hold up. Especially if I'm on a trail somewhere and it needs tightening.
thejafe is offline
post #6 of 14 Old 11-05-2005, 11:07 AM
Oman Jeep
Oman Jeep's Avatar
1. If you have the right shaped wrench.
2. If you're prepared to do a little cutting.
1 didn't work and didn't want to do 2 so I'll see if the flag nut ever fails on me... if it does then I'll cut and get a wrench in there.
post #7 of 14 Old 11-05-2005, 12:45 PM
Jerry Bransford
Administrator
I used a standard Craftsman open-end wrench and I did no cutting.
post #8 of 14 Old 11-05-2005, 01:29 PM
CreightonRea07
i didn't have any problem with any of the flagged nuts when I put my lift on or checked the torque specs
Me:
2000 TJ Sport
Dana 44
4.0L 5-speed
33x12.50 bfg Muds
MORE sport cage
re 4.5 w/ 3.5 springs
Little Brother:
'92 Cherokee Laredo
Stock but soon to be lifted
235/75 BFG All-terrains
lots of dings and scratches
CreightonRea07 is offline
post #9 of 14 Old 11-05-2005, 02:27 PM
VisitorJim
i did the same thing, just twist and turn the wrench and it'll fit, but it takes patience. there is no need to cut anything.
my nut got real loose once and that made it a real pain to get to. so if you switch from the flag nut do it right, use loctite. that rhymed.
1997 TJ Sport
3.5" RE Super Flex, Daystar 1"BL/MML, 33x12.5 ProComp MT's on Black Steel, 4.56 Gears, Front Lock-Rite, NV3550 swap, 33 Eng Skid, LuK ProGold Clutch, AA SYE, Tom Woods Front and Rear, Full Borla Exhaust, Turbo City Intake, Optima Red Top, Alloy USA Axle Seals, PSC Rockers, KC Daylighters, Xenon Flares, and lots of other small stuff that adds up $$$
1990 Kawasaki EX 500 - work in progress - more work than progress...
VisitorJim is offline
post #10 of 14 Old 11-05-2005, 06:20 PM
Oman Jeep
Oman Jeep's Avatar
Fair enoguh... craftsman must be a bit smaller than what I had access to because there was no way it was getting in there without modification to the wrench or the axle. Walking over to the parts counter for a new flag nut was the easy option
post #11 of 14 Old 11-05-2005, 09:15 PM
christopher6968
christopher6968's Avatar
2007 KJ Liberty
replaced mine with a grade 8 nut and bolt used a snap on wrench no problems getting to the nut at all
christopher6968 is offline
post #12 of 14 Old 11-05-2005, 11:31 PM
Texas TJ
Texas TJ's Avatar
i just picked up an extra nut for the front and back (i ripped the flag off the front one on a trail one time)
Texas TJ is offline
post #13 of 14 Old 11-05-2005, 11:47 PM
U.S.MarineLJ
U.S.MarineLJ's Avatar
Are you too experiencing the dreaded death wobble? I just installed my OME kit and the wobble scared the shyt out of me. Hope you get it resolved if that is your issue. I have had no luck thus far in correcting the problem.
Great site to read about and review Jeep related products.
Awesome site with writeups.
Another awesome site for writeups.
U.S.MarineLJ is offline
post #14 of 14 Old 11-06-2005, 06:36 AM Thread Starter
thejafe
thejafe's Avatar
From what I've read DW is often caused by a loose track bar. Mine DID become loose on the passenger side but I couldn't tighten it down because of this whole broken flag nut issue. So yes I experienced the DW on the highway doing 70mph. Fun .
thejafe is offline
How are your Moabs holding up? vtx531 TJ Wrangler Technical Forum 10 10-12-2009 09:20 PM
holding up the jeep will02sport TJ Wrangler Technical Forum 3 02-24-2008 07:55 AM
what is this holding my tire on? pic derfin TJ Wrangler Technical Forum 30 08-18-2007 09:38 PM
E-brake not holding..... primus TJ Wrangler Technical Forum 19 07-20-2006 05:09 AM
Holding down the hard top??? spark plug YJ Wrangler Technical Forum 11 01-29-2005 12:07 PM
