HITCH WIRING KIT TJ 98-06 Plug N Play - JeepForum.com
post #1 of 25 Old 05-16-2013, 04:14 AM Thread Starter
stevedplumber
i purchased the Hidden Hitch T-One Hitch Wiring Kit for my 06 TJ from quadratec. problem is i cannot locate the T-Connector on the passenger side. i can see the wiring that drops down from the drivers side, travels over to the passenger side between the gas tank and body and then splits in two different directions. but i cannot locate any T- connectors. i thought this would be a simple inexpensive fix to my trailer lights, was i mistaken?
stevedplumber is offline
post #2 of 25 Old 05-16-2013, 04:33 AM
4banged
I thought you only needed to tap into the driver's side...I did mine probably 2 years ago so its a little fuzzy but I thought all the wires you need were on drivers side t connection. I have an 03 but think would be same.
4banged is offline
post #3 of 25 Old 05-16-2013, 04:53 AM Thread Starter
stevedplumber
you would think they would all be the same..... lol!! i did search bothe sides and was only able to come up with a t-connector behind the drivers side.
post #4 of 25 Old 05-16-2013, 07:56 AM
BlueFizzy
BlueFizzy's Avatar
It has been a few years since I sold my 2005, but if I remember correctly they changed the wiring in 2005. There should be 2 different wirings kits.
2000 TJ Sport
2010 F250 PSD
Yellow Jeep Club Member #53
BlueFizzy is offline
post #5 of 25 Old 05-16-2013, 08:14 AM
TheRealZ
Junior Member
Correct there are 2 different ones depending on year.
TheRealZ is offline
post #6 of 25 Old 05-16-2013, 09:29 AM Thread Starter
stevedplumber
looks like i will be returning the Hidden Hitch T-One Hitch Wiring Kit since i do not have the other t-connectios on the passemger side...
post #7 of 25 Old 05-16-2013, 09:44 AM
JEK3
JEK3's Avatar
I bought one of those kits for the 98-04 TJ to put on my 06 LJ. The instructions said the connector went on the passenger side, but what I had didn't match. I found the connector in the drivers side, checked the wiring colors, and discovered that all Jeep did was move the connector to the other side. The kit works fine on the drivers side.
JEK3 is offline
post #8 of 25 Old 05-16-2013, 10:03 AM Thread Starter
stevedplumber
i will check again on the drivers side but all i saw was the wires come down through the grommet and go over to the passenger side with no t-connector.
post #9 of 25 Old 05-16-2013, 10:12 AM
JEK3
JEK3's Avatar
I did have to pull out the plastic piece on the bottom of the corner.
JEK3 is offline
post #10 of 25 Old 05-16-2013, 10:16 AM Thread Starter
stevedplumber
yeah i did pull out the plastic piece at the bottom underneath but only saw the connections for the drivers side. maybe there is something hinky going on with the 06
post #11 of 25 Old 05-17-2013, 02:30 AM
JEK3
JEK3's Avatar
I would look at mine for you, but there's currently about eight time zones between me and my Jeep.
Can you see all the wiring? Maybe mine's different since it's an LJ.
JEK3 is offline
post #12 of 25 Old 05-17-2013, 03:53 AM Thread Starter
stevedplumber
the passenger side. the wires going off to the right obviously go to the drivers side. the wires going up to a connector, but not a t-connector.
post #13 of 25 Old 05-17-2013, 04:02 AM Thread Starter
stevedplumber
this is the connector the wires going up go to...
post #14 of 25 Old 05-17-2013, 04:44 AM
Smeg
Have an 06 but got my wire kit from an online trailer place we used for work.
I'm pretty sure mine only connects on the pass side and then strings across to where you connect to trailer. I'll look after work.
'06 TJ Yellow nothing special
'15 WK2 Limited Deep Cherry Red Wrecked
'12 WK2 Laredo Black Wrecked
Smeg is offline
post #15 of 25 Old 05-17-2013, 04:46 AM
Smeg
I also remember pulling the pass taillight for better access.
Smeg is offline
