#1 | |
Hitch Wiring
I just installed a Reese hitch on my X. I got the wiring harness from Quadratec and went to install it. The harness is made by hidden hitch with 2 T connectors to plug into the factory harness. The problem is that the passenger side does not have a plug that I can connect into. The driver side is not a problem. Am I missing somethine??
#2 |
I installed a hitch and harness on a 2003 sahara last year and just three weeks ago on an unlimited. Look under the rear corner on the passenger side. You will have to pull back the plastic cover. The connector is wrapped in some kind of foam tape that you will have to pull away to be able to take the connector apart and plug your harness in. For the unlimited it was in the corner, for the 2003 tj it may have been a few inches closer to the wheel well. I do not recall exactly for the 2003. Both times it was wrapped in the dark grey or black foam tape. You should only have to plug into the one side.
#3 |
Looks like the passenger side is hard wired. I see the wires coming from the drivers side then it branches off to the the light without a connector. Looks like I am going to hae to splice it.
#4 | |
Ari Adler KD8CXP |
#5 | |
#6 |
Zookeeper - When you put on your hitch, were the bumber mounting bolts metric or standard? Mine are metric. In the Reese intructions, it said it could be either. Could be a clue.
#7 | |
Ari Adler KD8CXP |
#8 |
I just installed the Mopar harness in my TJ last weekend and didn't have a problem. Like Honaker said, there should be a connection wrapped up in a gray foam that you need to pull apart and connect the harness to. When you look under that splash shield, there is a wire that shoots across to the drivers side, but if you follow it up to the passenger tail lamp and move the wires around you should be able to find that connector mentioned above. It's not visible and takes some skootchin around to get it...
My Hidden Hitch had standard bolts and nuts. |
#9 |
I dug around and found it. It was stuffed pretty good up in the hole towards the tail light.
Thanks |
#10 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
