hiss noise from engine and doesnt wana down shift - JeepForum.com
post #1 of 5 Old 08-11-2009, 03:01 PM Thread Starter
emahan01
i jus changed the exaust manifold and it seemed to have fixed the diesel sound but after i got it all back together i drove it and it doesnt seem to want to down shift when i get on it and there is a hissing sound i cant seem to find. i can literaly smash the gas to the floor and it wont down shift and the rps jus slowly go up.
2.5 susp,1.25 body,aussie front 33x12.5 mud country, rokmen front,trail gear rear bumper, winch, straps
emahan01 is offline
post #2 of 5 Old 08-11-2009, 04:17 PM
Luke94XJ
1994 XJ Cherokee
sounds like a vacuum leak, I didn't know they had a vacuum kickdown, maybe they don't. Most likely that's the problem do you have a chiltons with a vacuum diagram or a underhood diagram on the fan shroud? you should check that see if there's anything going down to your trans. on the diagram.
Luke94XJ is offline
post #3 of 5 Old 08-12-2009, 12:54 AM Thread Starter
emahan01
bump anyone else have a suggestion from what i can see i put all the lines back together where they were
emahan01 is offline
post #4 of 5 Old 08-12-2009, 08:05 AM Thread Starter
emahan01
when i start the jeep it idles higher then before also im guessing i got a vacuum leak somewhere i dont know where it cld be though
emahan01 is offline
post #5 of 5 Old 08-12-2009, 08:32 AM
ZachAttack923
when we moved the intake i think we pinched a vaccum line and now its leaking cause remember the lines that we dident take off i think that one of those got pinched
2.5L Low Output #923
White Jeep Club #923
1997 Jeep Wrangler 2.5L AX-5 D30/35 4.10 gears
31in Wildcat A/T's
Originally Posted by j_niko View Post
I would be as nervous as a virgin on prom night if I had to drive that
ZachAttack923 is offline
Help! Went off-roading for the first time, now my auto trans doesnt shift out of 1st! phelan YJ Wrangler Technical Forum 39 05-28-2010 12:35 AM
Engine will turn over but doesnt run..... solja4jc TJ Wrangler Technical Forum 8 08-27-2009 06:29 PM
no spark, no fuel and engine light doesnt come on! HELP! Hussler YJ Wrangler Technical Forum 2 01-19-2009 06:40 PM
my engine cranks, but doesnt start TXjeepTJ TJ Wrangler Technical Forum 13 11-08-2006 06:01 PM
Grinding Noise when i shift? popemobile YJ Wrangler Technical Forum 2 07-15-2003 10:51 PM
