Highway Help ('00 TJ, 2.5 / Auto Trans) - JeepForum.com
post #1 of 6 Old 06-21-2011, 08:20 PM Thread Starter
CK3
So I have a 2000 TJ with a 2.5 & a 3 speed auto..(yea, yea, I know....) I'm running 32x11.5x15 ProComps.. The highway is KILLING me!!! 55/60 mph @ 3500/3700 rpm (with a headwind.... forget it!!) The real annoying thing is that the trans shifts non-stop between 2nd & 3rd constantly at 55/60 with the slightest incline in the road. Normal road driving is great... I just can't hit the highway...
Short of swapping in a 5-speed, doing a motor/trans swap or putting the stock wheels & tires back on... Is there anything I can do to enjoy driving this thing on the highway? My God please dont tell me to put lower gears in it.. lol.. with the 2.5L it would be faster to walk to work..
Thanks,
Bear
CK3 is offline
post #2 of 6 Old 06-21-2011, 09:26 PM
TheDodson
Thanks,
Bear
Put lower gears in. Only thing that will recoup the power loss. Your rig won't get slower by lowering gears it will actually get faster.
This is my jeep. There are many like it, but this one is mine.
TheDodson is offline
post #3 of 6 Old 06-21-2011, 09:31 PM
LilyBayXJ
Are you seriously running 3700 RPM at 60 mph? My 2.5 with the 5-speed runs about 2800 RPM at that speed, with 31's.
2006 LJ - 4.0L, NSG370, 31's
2001 XJ - 4.0L, AW4, 3.5" lift, 31's
1997 TJ - 2.5L, AX5, 2.5" lift, 32's - Sold
1983 CJ-5 - Stock - Sold
LilyBayXJ is offline
post #4 of 6 Old 06-21-2011, 09:38 PM Thread Starter
CK3
I meant slower acceleration with lower gears. The ole 2.5 isnt a rocket with the current gearing..
CK3 is offline
post #5 of 6 Old 06-21-2011, 09:41 PM Thread Starter
CK3
Yep... with stock wheels all is good.
CK3 is offline
post #6 of 6 Old 06-21-2011, 09:52 PM
rcman1993
lower gearing as in going from 4.11 to 3.73, or going 4.11 to 4.56 gearing, if you have the 4.11 gears, then if you get 4.56 gears, then your acceleration and rpm will increase but the 2nd to 3rd gear constant shifting will go away cause of the increase in power. i highly doubt that you are in 3rd gear with 32's and stock gears going 60 at 3xxx rpm, it should be like under 3xxx rpm. did you change the speedo gear with the new set of tires and have you had the transmission checked out? it might be slipping a little or your going like 80mph. very possible its that your going 80mph. in my jeep, i cant tell the difference between 60 and 80mph, im still holding on for my life.
rcman1993 is offline
I have a manual trans so can I run a radiator for auto trans? SteelBlueTJ TJ Wrangler Technical Forum 28 04-21-2011 02:43 PM
Auto trans to manual trans Wrangler_X TJ Wrangler Technical Forum 1 03-20-2011 04:38 PM
Is it easy to swap out my 3speed auto trans for the 4speed auto trans? bhicks TJ Wrangler Technical Forum 15 08-30-2010 09:30 AM
Trans Solenoid Problem ,Auto Trans Guys In Here gtospeeding TJ Wrangler Technical Forum 5 06-17-2010 07:33 AM
3 Speed Auto, 4.88's and the Highway Chris @ GATR TJ Wrangler Technical Forum 21 10-09-2007 05:25 PM
