Highbeams Stuck On - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Highbeams Stuck On
Steering Y-Link Adapter!Ruffstuff Axle Simple Swap Kit!Our Panhard / Trackbar brackets, Variations......
Unread 05-05-2013, 10:53 PM   #1
jcoty
Highbeams Stuck On
Hi all. I have an '04 TJ Sport 4.0 5speed that I just got a couple weeks ago so I'm still a bit new to TJ's. Anyways, I was driving today and all the sudden my highbeams indicator came on as did my headlights. I didnt turn them on or anything since it was still day light. I turned the car off but the indicator as well as the lights stayed on. I tried turning the lights on/off and pulling the highbeam switch but they wouldnt go off. I tried disconnecting the battery in hopes the gremlin would flee but to no avail. : any ideas as to what this could be and how to remidy the situation?
Thanks in advance
jcoty is offline   Reply With Quote Quick reply to this message
Unread 05-05-2013, 11:40 PM   #2
mikedff23
Sounds like you burn out the relay or the headlights high beam switch. Jeep wiring = the devil
mikedff23 is offline   Reply With Quote Quick reply to this message
Unread 05-06-2013, 08:39 AM   #3
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
Could be a few things. One is the multi-function switch, two is the headlight switch or three is the relay as mentioned above. Cheapest is option 3 with highest being option 1.
RnEmOvr is offline   Reply With Quote Quick reply to this message
Unread 05-06-2013, 08:41 AM   #4
jcoty
does anyone know how to fix these? or have a link to an '04 wiring diagram?
Unread 05-06-2013, 10:21 AM   #5
RnEmOvr
RnEmOvr's Avatar
Pick up a haynes or chilton manual. Both have very good decriptions on how to replace both parts.
Unread 05-06-2013, 10:23 AM   #6
jcoty
thanks for the reply. two more questions. in fixing the multi function switch would I have to remove the steering wheel? Would this pose issues with the airbag?
Unread 05-06-2013, 10:29 AM   #7
Jerry Bransford
Administrator
Jerry Bransford's Avatar
There is no relay in the headlight circuit. The only realistic thing such a problem could be caused by is the multi-function switch which also serves as the headlight switch on later model TJs as yours is.
No, you don't have to remove the steering wheel to replace the MFS and don't worry about the airbag. Two screws on the bottom of the plastic that surrounds the trim around the steering column come out to uncover the MFS. Then only a couple screws hold it it, with a plug-in wiring harness. You should be able to replace it with nothing more than a phillips head screwdriver.
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is online now   Reply With Quote Quick reply to this message
Unread 05-06-2013, 10:32 AM   #8
jcoty
No, you don't have to remove the steering wheel to replace it. Two screws on the bottom of the plastic that surrounds the trim around the steering column come out to uncover the MFS. Then only a couple screws hold it it, with a plug-in wiring harness. You should be able to replace it with nothing more than a phillips head screwdriver.
Sounds good, thanks for the reply!
Unread 05-06-2013, 10:35 AM   #9
gcrv01tj
Thanks in advance
Mine just started doing the exact same this over the past week or two. I have yet to chase down the problem. Let me know if the MF switch is the problem. I have had to replace it many times for other problems like the fogs staying stuck on but never the highbeams like this time.
gcrv01tj is offline   Reply With Quote Quick reply to this message
Unread 05-06-2013, 10:39 AM   #10
Ironhead
its really easy to replace the MFS. took me about 15 min.
got the part from autozone for $45
Ironhead is online now   Reply With Quote Quick reply to this message
Unread 05-06-2013, 01:31 PM   #11
RnEmOvr
RnEmOvr's Avatar
I thought there was a relay for the high beams? I can't remember for sure as I added one when I did my upgraded lights and harness.
Unread 05-06-2013, 01:42 PM   #12
Jerry Bransford
Administrator
Nope, there is no relay anywhere in the factory headlight circuit. At least neither my '97 nor my '04 TJ has a relay anywhere in the headlight circuit according to the schematic in the FSM. The only relay in the lighting circuit I know of is in the fog light circuit.
Getting Savvy...
Unread 05-06-2013, 01:49 PM   #13
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
Here's a good writeup with pics.
http://www.jeepforum.com/forum/f11/w...7/#post6129430
When I had 3.07s I would draft behind birds as an attempt to do the speed limit.
2000' WJ Limited 4.7L-V8/D44/Quadra-Drive/31" MT's/3" lift
TheBoogieman is online now   Reply With Quote Quick reply to this message
Unread 05-06-2013, 01:55 PM   #14
jcoty
Is a '98 XJ the same as an '04 Wrangler?
Unread 05-06-2013, 01:58 PM   #15
Jerry Bransford
Administrator
An XJ is a Cherokee & the '98 still used an old-fashioned pull-out headlight knob if I recall correctly.
Getting Savvy...
