High speed wobble and shaking - JeepForum.com
post #1 of 8 Old 02-24-2009, 06:03 PM Thread Starter
Gronkvist
As of lately my TJ has been experiencing some speed wobble when it exceeds speeds of 55 mph. The problem seems to be coming from the front end. I have a 4 inch Fabtech basic suspension system. I just replaced all the bushings on the lower control arms, so I know it's not that. Also, the steering feels a bit loose, but nothing nothing seems to be loose. For instance when I go over a bump, the steering wheel jerks to one side a little bit. Do I possibly need to upgrade to a better steering stabilizer?
Thanks
Gronkvist is offline
post #2 of 8 Old 02-24-2009, 06:18 PM
TJSport01
im sry i dont mean to be an *** but please please search there are tons and tons of thread devoted to death wobble, i will tell you this now a new stabilizer is not the answer, search, fill out your profile, and welcome
Build Thread:
2001 Jeep TJ, 1in JKS Body Lift, 35x12.50x15in Goodyear Mtr's and a RE 4.5 SF with AA sye, tom woods custom cv drive shaft, tnt tube fenders w/3in flares and flush mounted led turn signals, 1in mml, cobra cb and firestik, custom rock sliders, herced, trail scars
Looking for 4.88s (R&P) for a d44/d30 PM me
TJSport01 is offline
post #3 of 8 Old 02-24-2009, 06:18 PM
TJSport01
didnt realize your profile was filled out my bad
Build Thread:
post #4 of 8 Old 02-24-2009, 06:23 PM
DuRubi
Check your track bar up front some times the bushings go out or it need to be tightened up. But it also could be an out of balance wheel rotate your tires and see if that fixes the problem.
'04 Screamin' Solar Yellow Rubicon
(It's Gettin' There)
DuRubi is offline
post #5 of 8 Old 02-24-2009, 06:38 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
I don't think you have "Death Wobble" at 55! You have other problems.How's your tire balancing and alignment?Also welcome to JF!
GOLENJEEPTJ is offline
post #6 of 8 Old 02-24-2009, 07:27 PM
nbf6165
start with balancing tires
nbf6165 is offline
post #7 of 8 Old 02-25-2009, 01:50 AM
Jonny Jeep
Jonny Jeep's Avatar
My wobble that came in at 55 was caused by a tyre with sidewall damage. Replaced it recently with my unbalanced spare due to a puncture and the wobble is gone. May be a tyre with a bad sidewall.
Jonny Jeep is offline
post #8 of 8 Old 02-25-2009, 02:04 AM
HipCheck_1
Sounds like you may have bump steer.
Did you put on a drop pitman arm? If so did you also drop the track bar to match?
Did you get an alignment after the lift was installed? If not your toe will be off and that can cause wobbles.
I would also check both ends of the track bar and make sure they are torqued to specs as already suggested and also try swapping tires around to see if the issue goes away.
05 Jeep Wrangler 2.4l 4 cylinder
3" SL, 2" BL, 33 Eng belly up, 33x12.5 Pro comp MT
Low Ouput 4-cyl Jeep club member #151
HipCheck_1 is offline
Steering Wobble, high speed only tck1000 TJ Wrangler Technical Forum 45 07-28-2014 01:27 PM
High speed slight wobble DrDiesel TJ Wrangler Technical Forum 1 10-08-2009 07:24 AM
03 Rubicon Death Wobble (shaking) Dbower TJ Wrangler Technical Forum 15 06-18-2008 11:08 PM
High Speed Death Wobble. superubicon TJ Wrangler Technical Forum 11 01-09-2007 11:44 PM
Violent shaking- pretty sure its not death wobble geoff11 TJ Wrangler Technical Forum 2 09-16-2006 10:40 AM
