High Speed tire balancing. What will this acheive? - JeepForum.com
post #1 of 4 Old 11-02-2009, 07:59 AM Thread Starter
TheHeretic
Kool Kat 4x4
TheHeretic's Avatar
Morning! I'm about to get my TJ tires high-speed balanced. What is the advantage compared to regular balancing machine? I'm at a shop that does transport tires, and they have highspeed balancer.
VA3IPB
The only True Professional Mechanic in the Greater Toronto Area for Modified Jeeps, and trucks. If Rock Spyder hasn't seen it before, or done it before, you don't need it.
TheHeretic is offline
post #2 of 4 Old 11-02-2009, 08:10 AM
canyon47
Not sure what it would do for off road tires. I have a 350z and bought some yokohamas a while back. I had them balanced by the shop and while driving home they seemed unbalanced as soon as I passed about 83mph. Anything under that and they were fine. I went back to the shop told them of the issue and they did a highspeed balance for a little extra and now the car is stable up to max speed.
canyon47 is offline
post #3 of 4 Old 11-02-2009, 08:11 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
TheBoogieman is offline
post #4 of 4 Old 11-02-2009, 10:23 AM Thread Starter
TheHeretic
Kool Kat 4x4
TheHeretic's Avatar
Solved!!!!
Finally, the last remaining steering shimmy is gone!!! It turns out the last place that balanced the 31's only did a static balance. I didn't know the difference. Now after being balanced on a highspeed, staticly; the Jeep rides beautifully now. There is no shaking in the steering at any speed, any legal speed !
Did discover though that one of the tires cannot be balanced. The Tech said it was a bad tire, so its on the back. I drove it on the highway, and although one tire is out of round, and unbalanced I couldn't feel anything in the steering wheel OR in the seat.
If it does get bad again, I'll have to replace the two rear tires. Shame I went with expensive rubber though.
Good Year Silent Armor Wranglers arn't cheap, but oh well. I got them second hand so I don't even have the receipt.
VA3IPB
A/C blows defroster at high speed, regular at low speed tumminello123 TJ Wrangler Technical Forum 3 07-11-2009 11:15 PM
mygig high speed vs. low speed orangeconv JK Wrangler Technical Forum 6 10-06-2008 12:05 PM
tire balancing problem olesahara YJ Wrangler Technical Forum 6 08-13-2008 03:23 PM
tire balancing question mic6 TJ Wrangler Technical Forum 6 02-04-2008 04:12 PM
Tire Balancing AeroE TJ Wrangler Technical Forum 4 06-28-2006 12:05 PM
