High RPM on highway 1999 4-cyl - JeepForum.com
post #1 of 7 Old 08-23-2014, 02:28 PM Thread Starter
gjohns25
I recently bought a 1999 automatic Jeep Wrangler 4-cyl and while driving on the highway the RPM read around 4000-4500 going about 65-70mph. This seems high to me, but this is my first jeep. Is this normal? If not, what could be causing this?
gjohns25 is offline
post #2 of 7 Old 08-23-2014, 02:57 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
RPM should be closer to 3,400 at 70 MPH with stock size tires and stock axle gear ratios.
What size tires do you have?
Are you sure the speedo is accurate?
Wheelin98TJ is offline
post #3 of 7 Old 08-23-2014, 03:02 PM Thread Starter
gjohns25
Tires are 31x10.50-15
Not sure if those are stock sized
gjohns25 is offline
post #4 of 7 Old 08-23-2014, 05:19 PM
Wheelin98TJ
JEEP FREAK
31 x 10 50 is not the stock size. It is taller and wider.
The taller tires would drop your rpm at highway speeds.
You may have a different gear ratio in the axles.
Rotate your tires one complete revolution while counting driveshaft revolutions. That'll tell you the axle gear ratio. Or if you are due for a diff fluid change, open up the diff and find the ring and pinion tooth count stamped on the side of the ring gear. There is more info in the FAQ sticky thread on how to determine your gear ratio if I'm not being clear.
post #5 of 7 Old 09-01-2014, 04:38 PM
chuck85225
With the same tires you have I'm at 3000-3100 rpm at 70 with stock 3.73 in my 98
chuck85225 is offline
post #6 of 7 Old 09-01-2014, 04:46 PM
afusco1222
Has the Jeep ever been lifted or have bigger tires on it? Sounds like the PO had upgrades on it, and took them off to sell the Jeep.
afusco1222 is offline
post #7 of 7 Old 09-01-2014, 06:53 PM
2jhanna
This was my thinking also. Maybe had bigger tires and lower gears. Then took the tires off to sale and left the lower gears in.
jhanna
denton county, tx
2jhanna is offline
4-cyl , rpm
