high oil pressure - JeepForum.com
post #1 of 6 Old 07-22-2008, 04:22 PM Thread Starter
Sunvista
high oil pressure
My wife called me from her '02 X to tell me her oil pressure gauge is pegged. She hasn't driven the Jeep in a long time so she didn't remember what it "usually" is. When she got home I looked at it and it wasn't pegged but was reading just below 80 psi at idle on a very hot day. The owners manual indicates normal pressure between 45-65 psi. I'm generally concerned with low oil pressure but do I have a problem here at 80 psi?
'02 Wrangler "X" 4.0 APEX
Sunvista is offline
post #2 of 6 Old 07-22-2008, 04:24 PM
Moses2564
I would bleed the lines just to make sure, sounds like you might have some sludge build up, causing an increase in pressure. The increased pressure might put excessive wear on the seals, and cause them to leak.
2000 Solar Yellow TJ
2000 Ford F250 Super Duty
2006 Volvo S40
1997 Arctic Cat ZRT 600
Moses2564 is offline
post #3 of 6 Old 07-22-2008, 04:51 PM Thread Starter
Sunvista
Bleed the lines??? What in the world does that mean?
Sunvista is offline
post #4 of 6 Old 07-22-2008, 04:57 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
You don't bleed oil lines, I'm not sure what he was talking about. I'd first change out the oil pressure sender which is mounted next to the oil filter. The sender is responsible for most oil pressure gauge problems. Before actually buying it though, unplug its connector first and clean it, then reseat the connector. Could just be a dirty/weak connector that connects the wiring to the sender.
Jerry Bransford is online now
post #5 of 6 Old 07-22-2008, 05:19 PM
Moses2564
Oops, my head was in the clouds, has been all day, I have a cold and am doped up on robotussin . What I think I meant to say was to drain the old oil out, being that she hadn't driven it in a while.
2006 Volvo S40
post #6 of 6 Old 07-22-2008, 06:03 PM Thread Starter
Sunvista
Thanks. I'll give that a try.
Sunvista is offline
Oil Pressure.... too high? MikeyJ YJ Wrangler Technical Forum 13 05-09-2009 11:41 PM
Restart Idle High and High Oil Pressure bringbackphish YJ Wrangler Technical Forum 2 12-09-2008 09:46 PM
High Oil Pressure Tom Kuhn YJ Wrangler Technical Forum 12 04-28-2007 09:14 AM
oil pressure high heapofjeep YJ Wrangler Technical Forum 9 03-14-2006 08:41 AM
Very high oil pressure BigD1634 YJ Wrangler Technical Forum 3 11-28-2001 07:40 AM
