High Lift Roll Bar Mount write-up (with pics) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > High Lift Roll Bar Mount write-up (with pics)
Jeep Long Arm Upgrade Kits on SALE for as low as $649.95 SKOR Name Your Price SaleThe Original 3/8" Ruffstuff Diff Cover!
Unread 06-06-2009, 07:06 PM   #1
TJ311
I'm putting this here because I did this with my TJ but I imagine it will work for YJ's too.
I've seen a lot of different high lift jack mounts but very few write-ups and even fewer parts lists, so I thought I'd create one. Maybe this can go in the Newbie Guide.
I finally decided to mount my high lift inside my Jeep to keep it out of the elements and still keep it accessible. It's pretty straight forward really. I'll let the pictures do most of the talking here.
Parts list:
  1. 2 x 2.5" muffler clamps (got mine at Checker Auto for about $4 total.)
  2. 4 x 10mm-1.5 wing nuts (picked up at Home Depot for a couple bucks.)
Driver's side muffler clamp will face passenger's side. There are 2 holes in the bottom of my high lift that allowed the muffler clamp to basically slide right in although I had to enlarge the holes just slightly to allow the base to slide over the threads a little easier.
The passenger side muffler clamp will face backwards. My high lift didn't have a hole for the clamp to slide through so I drilled a 3/8" hole for it.
Placement was pretty critical. I initially tried to mount it up above the seat belt mounts to keep it high but the wiper motor cover for the back window hit it when closing. Soft top owners probably won't have this issue. So I had to mount mine below the seat belt mounts. I had to mount it high enough though so the back seat didn't hit it.
Finished from the inside.
Using the 2.5" clamps fit perfectly and when tightened down, the jack is rock solid. All for under $10. I also thought about drilling holes through the threads of the clamps and using just pins for even quicker release but wanted the mount as solid as possible.
Hopefully, this will help somebody else.
TJ311 is offline   Reply With Quote Quick reply to this message
Unread 06-06-2009, 08:33 PM   #2
Mean Max
Don't poke the bear
Mean Max's Avatar
It looks great! I've seen that done before, but you did a really great job on the write-up, and the pictures are top-notch!
It will work for YJ's, from '92-'95. They have the "family bar" roll bar like you have. The '87-'91 YJ's have the "sport bar" roll bar that looks like the CJ bar.
Very well done!
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote Quick reply to this message
Unread 06-06-2009, 08:33 PM   #3
Finsup
Nice write up, great job and looks like one of the best places to keep it.
Oh No....a drug dealer is here!
Low Output 4 Cylinder Jeep Club #453
Finsup is offline   Reply With Quote Quick reply to this message
Unread 09-13-2009, 12:22 AM   #4
TJ_Jeeper_97
Doing that tomorrow for sure!! Great write up!
97 TJ---31s, Custom Snorkel, 2'' lift, 4' firestik, hood mounted lightbar, body damage...
Ronin Wheelers of New England
TJ_Jeeper_97 is offline   Reply With Quote Quick reply to this message
Unread 09-29-2009, 07:25 PM   #5
CoolHipJim
Hi, was this a 60" or 48"?
CoolHipJim is offline   Reply With Quote Quick reply to this message
Unread 09-29-2009, 07:33 PM   #6
rs4race
looks like a 48. I just got one and put it in there except not bolted up, its just sitting across bungeed down, a 60 wouldnt fit in there.
nice write up tho, looks like this will be my next mod.
rs4race is offline   Reply With Quote Quick reply to this message
Unread 09-29-2009, 07:36 PM   #7
nicolas-eric
does a softtop still open with the hilift there?
if not i´ll weld me such a mount next weekend:
http://www.ottensmeier-us-cars.de/fa...e/SDC18604.JPG
4" OME & 1" Spacer & LT Shocks • 2" BL • 1" MML • JKS Discos • JKS Rear Links • OME Steering Stabilizer
35x12.5x15 Cooper STT @ 8.5x15 • ARB Airlockers • ARB Diff Covers • 4.56 Gears • SS Brake Lines
Warn Skids • Genright Rock Slider • Smittybilt Rock Crawler Rear Bumper • Safari Snorkel • OBA
12.000 lbs Winch • Synthetic Winch Line • 4x 130W Hellas • 4x 200W Hellas @ Lightbar • E-Fan
Jeep TJ Runicon Pics www.timbercrawler.de
nicolas-eric is offline   Reply With Quote Quick reply to this message
Unread 09-30-2009, 01:41 PM   #8
CoolHipJim
I did the same thing because as I was trying to fit the 48" hi-lift across the rear bars as the OP did, I noticed the top of my jack was pocking the soft top of my 04' TJ and I didn't like that. Just something to keep in mind for you soft top guys...
So I just laid it across and used the goofy straps that came with the TJ for the car seat or something to tie it down, and a piece of cardboard to keep the end of the jack from rattling on the rollbar.
Does not interfere with the tailgate or closing the softop back window
Unread 11-07-2009, 05:46 PM   #9
JFjeld
Thanks for the write-up. Bought a hi-lift today and mounted it this way. Appreciate the help.
- 2001 2.5L TJ, hpD30/D44 with dual OX and 4.88, full armor, X2O-8 winch, 35" STTs on 15x8 black steelies, 1" BL, 1" BD MM, 4.5" suspension, all-adjustable control arms, tie rod upgrade, OBA
- Jeep Build: http://s1186.photobucket.com/albums/...ld/Jeep_Build/
JFjeld is offline   Reply With Quote Quick reply to this message
Unread 11-07-2009, 06:11 PM   #10
gaTJgal
Holy mother of gawd dude. BAD BAD LOCATION FOR THAT!!!
What happens in a car wreck? Or even driving on the trails? Your head flops around, often snapping backwards. At the least your passengers will get a bump....at worst (and most likely in a car wreck) a head injury they may not survive. Our noggins don't do well with hard hits to STEEL yanno?
Drop it down behind the seat at least man...
___________________________________________
I have a haynes manual, tools, and gloves so I don't ruin my nails. Oh yea--let the fun begin!
gaTJgal is offline   Reply With Quote Quick reply to this message
Unread 11-07-2009, 06:46 PM   #11
Jim Shanks
Yeah, good install, but you might want to lower it down the bar a bit. I have mine about 8 or so inches lower than yours for that reason.
Jim
"Cracked Cow" '01TonTJ2a, Solid Mfg HP60's, 5.38's, ARB's, PSC full hydro, 14" coilovers, ASD roof and doors, armored everywhere sitting on 40" Iroks.
Owner of IA4x4.com
Subscribe to CRAWL
Jim Shanks is offline   Reply With Quote Quick reply to this message
Unread 11-18-2009, 08:18 PM   #12
lvjeeps
Just an FYI...
The RED Hi-Lift (All Cast) model's holes on the base do not line up with the 2.5" exhaust clamp as shown with your model above(Cast/Steel). Your best option will be to use only one hole from the base.
If you want to use two holes for mounting, you will have to enlarge one of them. By using this method you will find that the ratchet mechanism will press into the back of the seat and could poke a hole in it...(that is, if you want to mount it low). If you don't mind it being mounted high and in your line of sight along with the safety issues go for it. I only used only one hole on my base to mount it, it's low and 2"inches away from hitting anything. No ratles or shakes. Good write up. Quadratec selles a similar type of mount for around $80. My good man,thanks for saving me $70!
lvjeeps is offline   Reply With Quote Quick reply to this message
Unread 11-18-2009, 10:19 PM   #13
rs4race
I just finished this. I missed the part about drilling a new hole, but worked around it. I mounted it just under the level of the rear seat so no worries about passengers hitting heads. it just sucks to use the back, because its so low and in the way, but at least it is not floating around!
Unread 11-18-2009, 10:28 PM   #14
nicolas-eric
do you have some pics ?
Unread 11-18-2009, 11:41 PM   #15
Jayson44
I mounted mine the same way. but with the base sitting on the plastic seat belt cover thingy...and below the seat too.
J.
98 TJ Sahara patrolling the FSRs above Denver...
Colorado Jeep Club Member #280
Jayson44 is offline   Reply With Quote Quick reply to this message
