High Beam Issue - JeepForum.com
post #1 of 3 Old 04-10-2012, 11:05 PM Thread Starter
mach1laterzz
High Beam Issue
After much reading and serching here and on the internet I still have not resolved my problem. My highbeams only turn off when manually holding the multifunction switch in the rear position. So, after searching and reading similar issues I have done the following, replaced multi function switch, replaced headlamps, replaced headlamp sockets, checked grounds at headlamps, checked fuses, checked relays, and have determined I do not have a Canadian model TJ, so no daytime runing lights, and replaced a badly corroded connector on the green wire that connects to multi funtion switch. What am I missing. Thanks for your help and advice.
mach1laterzz is offline
post #2 of 3 Old 04-10-2012, 11:43 PM
DustFloor
Have you read through this thread?
http://www.jeepforum.com/forum/f9/he...e-help-544713/
OlllllO Black Jeep Society
2001 Wrangler TJ
*1999 Wrangler TJ *SOLD*
DustFloor is offline
post #3 of 3 Old 04-14-2012, 12:04 AM Thread Starter
mach1laterzz
Thanks ill try using those diagrams
99 TJ high beam jer99tj TJ Wrangler Technical Forum 5 05-26-2012 05:26 PM
Headlight/High beam fuse issue? YJtuttrain YJ Wrangler Technical Forum 1 01-30-2012 07:41 PM
High beam and low beam combined? imstillatwork YJ Wrangler Technical Forum 13 06-02-2010 06:58 AM
Headlights: Low beam broken, high beam lever doesnt "click" blizzy YJ Wrangler Technical Forum 5 05-24-2009 07:11 AM
High beam ?'s cjb7804 YJ Wrangler Technical Forum 2 02-19-2005 01:58 PM
