High beam indicator light stays on - JeepForum.com
post #1 of 2 Old 07-23-2010, 08:18 PM Thread Starter
VMI Jeeper
Alright, so I just drove home from work and my high beam indicator light on the dash stayed on nearly the whole drive home.
When I started the jeep up, the indicator was on. I flashed my brights a couple of times to see if it would turn off and it did after a few times. As I got on the highway the indicator lamp came back on and I didn't turn on the brights anymore. It stayed on for about 10 miles and then went off again. It stayed off the rest of the drive home with the just the low beams on.
Now while I was at work we had a pretty nasty thunderstorm roll through. Since I am only running the safari top and duster cover with no doors, the jeep got a little wet (definitely not the first time). I did have the seats folded forward to help protect the dash as much as possible.
Now I'm not too worried about this since the indicator light eventually went off. However, I was just wondering if this was some type of warning if the light stayed on? That or maybe the switch in the steering column got a little wet and was malfunctioning?
Just looking for some other ideas/opinions or if anyone else has experienced this!
VMI Jeeper is offline
post #2 of 2 Old 07-23-2010, 09:49 PM
wushaw
Rockin jeep
wushaw's Avatar
Switch got wet, let it dry.
wushaw is offline
electric , electrical , high beam , dash , light , tj , wrangler
Strange high beam indicator problem SaxManClay TJ Wrangler Technical Forum 2 05-11-2010 03:33 PM
High beam indicator rattlewagon JK Wrangler Technical Forum 19 01-11-2010 01:48 PM
One of mt headlights stays on high beam Nemoralis TJ Wrangler Technical Forum 11 06-21-2006 01:48 AM
High Beam Indicator Light Ged YJ Wrangler Technical Forum 1 12-22-2005 06:17 PM
