Hidden fees of a lift? - JeepForum.com
post #1 of 29 Old 08-03-2010, 11:08 PM Thread Starter
Devin6199
If I get a 4 in suspension lift on my '97 wrangler, would I have to make any driveline modifications, like buy an extended drive shaft?
Any one that knows alot about lifts and would like to share that knowledge, please feel free to post.
Devin6199 is offline
post #2 of 29 Old 08-03-2010, 11:44 PM
fang_x
We installed a 4inch lift on my old jeep, it came with a transfer case drop kit, and it runs fine! the drivle line angles are okay.
'98 TJ Manual -2.5" rcx long arm on 31
'99 Xj, Stock on 30"
'86 Monte Carlo 357 stroker. 450hp.
fang_x is offline
post #3 of 29 Old 08-04-2010, 01:35 AM
pdangerp
pdangerp's Avatar
The only hidden lift fees are the ones that you didn't research enough to know to expect.
pdangerp is offline
post #4 of 29 Old 08-04-2010, 03:44 AM
BlueFlame
BlueFlame's Avatar
4" is the magic number.
Usually, 4" results in the need for adjustable control arms, Slip yoke eliminator, and a new CV driveshaft.
Some rigs seem fine with 4' lift without those things, but most are not.
BlueFlame is offline
post #5 of 29 Old 08-04-2010, 04:03 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
All the 4" RC lifts I have installed over the years only required a MML and 1/2" t case drop with washers to get rid of all vibes.I did the MML so I wouldn't have to use the huge 1.5" t case drop that comes with the kits.
TheBoogieman is offline
post #6 of 29 Old 08-04-2010, 08:16 AM
Streetbyker13
My 4" is great with no vibes, came with extended lower control arms but they aren't adjustable. I used the t case drop that came with mine but plan on changing to the MML pretty soon to get some of my clearance back
Streetbyker13 is offline
post #7 of 29 Old 08-04-2010, 08:44 AM
WillysGSR
What is a MML?
WillysGSR is offline
post #8 of 29 Old 08-04-2010, 08:51 AM
Imped
Imped's Avatar
Yep. Nothing is hidden if you know what's going on. With 4" of lift, a hellofalota stuff is needed or else you'll be running offset axles, a shrunk wheelbase, and a t-case drop. If you would research and read build threads instead of post this thread, all of your questions would be answered. Wouldn't it be nice to know you found all of that info yourself?
OlllllllO
IndyORV
Imped is offline
post #9 of 29 Old 08-04-2010, 10:55 AM
TheBoogieman
Originally Posted by WillysGSR View Post
What is a MML?
Motor mount lift.It helps with driveline vibes.
post #10 of 29 Old 08-04-2010, 10:57 AM
TheBoogieman
That's way too much work.
post #11 of 29 Old 08-04-2010, 12:16 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
x10000. Control arms, SYE/CV shaft, proper bumpstop extensions, wider flares, tires & wheels with less backspacing, discos, rear sway bar links, rear shock mount relocation to clear the spring perch, track bars, front sway bar discos, rear CV track bar bracket, brake upgrades, steering upgrades, welding reinforcements on multiple brackets so they don't rip off, regearing & lockers...all "hidden" costs of lifts.
some of us like to do stuff right so it works
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #12 of 29 Old 08-04-2010, 06:20 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Not if you want to go off road...
Knuckelhead is offline
post #13 of 29 Old 08-04-2010, 06:21 PM
Knuckelhead
AFSOC Retired
Yep!...
post #14 of 29 Old 08-04-2010, 08:06 PM
chilipepperjeep
To my non-jeeping friends I've described the process of lifting my TJ like the pulling of a loose thread in a sweater. It's only a 4" lift, how hard can it be? It's only a loose thread, lets just pull on it, oops the sleeve just fell off. Just plan on putting in all of the other stuff, because you're going to do it anyway.
chilipepperjeep is offline
post #15 of 29 Old 06-15-2013, 07:55 PM
1971CJ5Man
So if I install a 1" body lift and a 1" MML I should be able to remove my 1" t case drop pucks?
1971CJ5Man is offline
driveline , modifications
Jeep annual fees/taxes/insurance costs/etc AlexGeorgakis Wrangler General Discussion 7 12-07-2009 07:51 AM
Hidden nut on lift question? thunderbyte TJ Wrangler Technical Forum 14 07-26-2009 05:01 PM
How much in shop fees for all this work? DINOCAVE Wrangler General Discussion 14 05-20-2009 08:11 PM
Extra Destination / Delivery Fees on Dealer Invoice? YlwColumbia JK Wrangler Technical Forum 5 02-06-2007 12:14 AM
DAA and PPA fees on jeeps..are they Negotiable? ajaxbro TJ Wrangler Technical Forum 1 07-27-2004 04:50 AM
