Quantcast Hi-Lift Mount for 5 bucks and 5 minutes! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Hi-Lift Mount for 5 bucks and 5 minutes!
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 10-17-2009, 01:08 AM   #1
dbornemann
I got tired of my hi-lift either sitting in the garage or rattling in the back seat since I don't have a proper mount. After seeing this crock of sh!t for $80...
Quadratec Exclusive TJ-HLJM - Sport Cage Hi-Lift® Jack Mount for 97-06 Jeep® Wrangler TJ & Unlimited - Quadratec
I figured there's gotsta be a better way.
So on my next trip to Autozone I found exhaust clamps for $2.49 a piece. I picked up one 2.5" and one 3" and went home to see what I could do. Well, literally 5 minutes later my jack was hanging from the roll bar with the help of a 3/8" wing nut I had laying around.
Once the design was complete (if you can call it that) I took it back apart and refined it to what you see here. I had to relocate the tab that was at the top of the neck to a few bolt holes lower. I added some split rubber hose between the jack's upper neck and the flat part of the clamp to reduce vibrations. I put a big flat washer behind the wing nut, then made a rubber "washer" from some hose to go behind the washer as well. Then I painted all the hardware flat black and bolted it back up.
It's been hanging like that for a few weeks now and I have ZERO complaints. It doesn't vibrate at all. It removes without tools. It works with no top, soft top, AND hard top. And best of all...it cost $5.
1999 TJ (my first Jeep without a carburetor!)
RE 2" BB and Moab's / MTR's, pretty much stock otherwise
dbornemann is offline   Reply With Quote
Old 10-17-2009, 01:10 AM   #2
flexsaharatj
2004 VJ
good idea looks good, but done before fyi
WTB: 98-04 Jeep TJ Wrangler, miles under 120k, I6, manual. Lifted a plus, let me know what you have!! Looking to spend >$5000
2004: Nissan Xterra: SOLD
WJ: Lemon Dealer bought back
Sold: 97 Sahara TJ
Firefighters Jeep Club
flexsaharatj is offline   Reply With Quote
Old 10-17-2009, 03:01 AM   #3
G-MANtj
if you flip it over so the jack part is facing down then no one will hit their head on it in the backseat and it still works the same
/| ,[___],
|---L-o||||||o-
()_)-()_)-o-()_)
G-MANtj is offline   Reply With Quote
Old 10-17-2009, 09:54 AM   #4
SHAKEnBLAKE
SHAKEnBLAKE's Avatar
It's hard to visualize this, but if I mounted it higher up, would passengers hit their heads?
Shake & Bake with SHAKEnBLAKE - "Build Thread"
www.ohio4x4.com
98 pile o' parts: 4.0L, 3spd auto, 4", 35" KM2s, XRC8, 4.10s, MCE flatties, KOZ cage
SHAKEnBLAKE is offline   Reply With Quote
Old 10-17-2009, 02:35 PM   #5
G-MANtj
yes. i have had this same setup for a few months and mine is level with the top of the backseat. no one can hit their head and it is still out of the way.
/| ,[___],
|---L-o||||||o-
()_)-()_)-o-()_)
Old 10-19-2009, 03:11 PM   #6
Deacon
Purveyor of Funk
Deacon's Avatar
G-MANtj and others who've had it that way for a while, has it torn up or otherwise messed with your rollbar padding or the fabric covering it?
Deacon is offline   Reply With Quote
Old 10-19-2009, 03:50 PM   #7
Strebs
220 221 whatever it takes
Strebs's Avatar
Cool idea! Thanks.
Strebs is offline   Reply With Quote
Old 10-19-2009, 04:08 PM   #8
G-MANtj
i haven't noticed any tears. if you make sure the pad is straight when you mount the jack it should be fine.
/| ,[___],
|---L-o||||||o-
()_)-()_)-o-()_)
Old 10-19-2009, 04:31 PM   #9
Deacon
Purveyor of Funk
Deacon's Avatar
Cool, thanks.
Old 10-19-2009, 05:01 PM   #10
Eric554
Do you think a folded down soft top would get caught or rip with the jack there? Thats the only thing holding me back from doing this.
Eric554 is offline   Reply With Quote
Old 10-19-2009, 05:11 PM   #11
Jeffro06
Dreaming of Moab
Jeffro06's Avatar
I did mine, in my YJ, just recently. The headrest on my seat keep the jack from becoming an issue.
I can't imaging Q-tech is actually selling too many of those $80 brackets, which are basically the same thing.
Member of Jeeps Going Wild and IndyORV
My Jeep Pictures
Jeffro06 is offline   Reply With Quote
Old 10-19-2009, 06:10 PM   #12
BYuen
Wahoowa
BYuen's Avatar
Nice! Good setup. I used fence clips before I got my rear bumper and tire carrier. The U-bolts are definitely a better mount.
White 01 TJ Sport 4.0 NV3550
BYuen is offline   Reply With Quote
Old 10-19-2009, 06:13 PM   #13
G-MANtj
nope, i had my top down with the jack there with no problems.
/| ,[___],
|---L-o||||||o-
()_)-()_)-o-()_)
Glock Forum
