HF winch plate Trimming to fit PIctures - JeepForum.com
post #1 of 3 Old 06-10-2010, 01:57 PM Thread Starter
Madmanmiller802
Can someone post a pic of their universal HF winch mount on a TJ i need to see exactly where it mounts. Under the sway bar???
Anyway would appreciate it
thanks
Should have probably bought a better winch plate but too late now....
oh well
also how they cut it.....haha
2004 Jeep Wrangler Rubicon
Yellow Wrecked For Now
Madmanmiller802 is offline
post #2 of 3 Old 06-11-2010, 11:25 AM
Mud Machine
Jeep Addict
Mud Machine's Avatar
Sorry no pictures from me but thought I would suggest that you might get a better response if you post this in the "Picture request forum".
BDS Springs, MetalCloak Arms, Fox Shocks, Warn Winch, Savvy Ft Bumper, Antirock, GenRight Fenders, GR8 Top, Rock Hard Cage, 5.13's, Revolution Axle Shafts, LS-III, 4L80e
'76 CJ-7, 33" Swampers, 6-Point Cage, 4-Speed, Dana 300 Twin Stick
Mud Machine is offline
post #3 of 3 Old 06-11-2010, 12:06 PM
03rubiconMG
typically the sway bar goes over the winch plate and if it goes that far back then i would drill through the winch plate and get longer bolts for the sway bar mount to hold that part of the plate down.
As far as cutting it down? im assuming its too wide? make it as wide as the frame and be able to be bolt into where the tow hooks bolt down for added strength.
Cut it with a cut off wheel, you will get the straightest most accurate cuts that way.
2003 white rubicon on 37s
03rubiconMG is offline
R/C winch plate & 8500lb Super winch on factory bumper. fernjack JK Wrangler Technical Forum 17 11-23-2010 10:12 AM
I'm an idiot.. and ordered a winch.. (Winch plate for stock bumper) RVA_TJ06 TJ Wrangler Technical Forum 32 12-26-2009 08:35 AM
Which winch plate for TKH Fab bumper + Warn winch? Achped TJ Wrangler Technical Forum 4 10-21-2009 02:56 PM
Torque specs for winch and winch plate jeep_chinto TJ Wrangler Technical Forum 6 02-18-2006 12:59 PM
Bolt size for winch to winch plate? Stricken TJ Wrangler Technical Forum 3 02-03-2004 09:17 PM
