Hesitating/Bucking issues (very specific) - JeepForum.com
post #1 of 8 Old 03-16-2017, 09:51 PM Thread Starter
064banger
Hi
My TJ has started to hesitate/buck at specific times making it occasionally dangerous when turning in front of oncoming traffic. Do you guys have any ideas?
Starts: fine
Idles: fine
Revs: fine
Accelerating (<15% throttle): fine
Accelerating (>15% throttle): will hesitate in every gear whenever under 2500 rpm. Above that its fine. The further down I press the throttle the worse it gets until I get over 2500 rpm.
Thanks
064banger is offline
post #2 of 8 Old 03-17-2017, 04:58 AM
DockRocker
What have you done so far? Any codes?
Without more Intel I would suggest the usual. Clean the throttle body and air intake control AIC. Next step for me would be TPS as it seems to be throttle sensitive.
Sent from my iPhone using Tapatalk
DockRocker is offline
post #3 of 8 Old 03-17-2017, 08:52 AM Thread Starter
064banger
No codes unfortunately.
I've not made any attempt to fix it yet, I wanted to see if anyone had any ideas of where to look first. I've read it could anything from a bad TPS (as you said) or a failing fuel pump.
post #4 of 8 Old 03-17-2017, 09:40 AM
RicanLJ
Check the fuel pressure...........
RicanLJ is offline
post #5 of 8 Old 03-17-2017, 10:41 AM
bparsel
2011 JK Wrangler
When my '99 had a similar issue it was the O2 sensor.
bparsel is offline
post #6 of 8 Old 03-18-2017, 06:09 PM
esad_b
Front O2 sensors on my 97 did something similar. Then a few years later, the crank shaft sensor, the thing would sometimes start fine but when I tried to drive it would feel like a riding a bull as it was bucking and jerking around.
esad_b is offline
post #7 of 8 Old 03-20-2017, 09:46 PM
baldness0351
Junior Member
I have the same issue. I have cleaned the throttle body, replaced the TPS, AIC, and 02 sensor. It only does it occasionally. I'll check the fuel pressure and look into the crankshaft sensor.
baldness0351 is offline
post #8 of 8 Old 03-21-2017, 09:50 PM
lizard20
My 2000 TJ 4.0 did the same thing. I replaced the crank shaft sensor, and no more issues.
2000 Jeep Wrangler Sahara, 4.0, Auto trans., Forest Green. 33x12.50x15, 2"BB, 1"BL.
Christian Jeep Club Member #65
lizard20 is offline
