Heresy: No lift 33" tires - Page 2 - JeepForum.com
post #16 of 18 Old 02-27-2014, 07:17 PM
TechJeeper
I'm interested in this too. Helping a friend stay budget and get 33s under the jeep. Current plan is 1" BL, major fender and flare trim, longer shocks to change the travel from even up and down to more down than up, SYE and tummy tuck.
TechJeeper is offline
post #17 of 18 Old 02-27-2014, 07:37 PM
mudb8
want it rite or rite now?
mudb8's Avatar
Chop the hood, raise the stock fenders 3.25". Bolt on the 33's, install 4:88 gears.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #18 of 18 Old 02-27-2014, 07:46 PM
mudb8
mudb8's Avatar
Balance the travel. The More down travel you create, the worse your ride will be and will create an even more pronounced tire to hood line problem. Non highline Flat fenders are not the answer.
mudb8 is offline
33s , no lift , tj
