Here's a good on :: Drivers Seat relocation. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Here's a good on :: Drivers Seat relocation.
The Cure for your Tie Rod Roll!Steering and more from Ruffstuff!Introducing MONSTALINERô UV Permanent DIY Roll On Bed Line
Unread 11-27-2006, 03:57 PM   #1
The Zombie
Junior Member
The Zombie's Avatar
Hey yall,
I drive a 99 tj sport..
..has anyone relocated their drivers side seat? I'm about 6'5" and the knees get smoked when hittn the trails, and not even the serious trails that i want to do.
*** does anyone have any links, ideas or suggestions and also DO YOU THINK THIS RELOCATION WOULD COMPRIMISE THE AIR BAG??***
please let me know. Thanks.
The Zombie is offline   Reply With Quote Quick reply to this message
Unread 11-27-2006, 04:01 PM   #2
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
It will have no effect on the air bag.
The air bag sensor measures deceleration and deploys the airbag accordingly. The position of the front seat is irrelevant.
Wheelin98TJ is offline   Reply With Quote Quick reply to this message
Unread 11-27-2006, 04:10 PM   #3
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
Position of the seat does not affect the airbag going off... though it can affect the airbag target, causing you to hit the airbag at the wrong moment or in the wrong position.
However, if you're that tall, moving the seat back will probably put you back where you're supposed to be anyway... since the TJ is probably designed around a more average height person.
There was a relocator bracket called the "Big Daddy bracket" or something like that made to move the early TJ seats back 2½" or so... you might want to look into something like that.
My Hummer Hole video
SIRA 4x4 club
I'll be Savvy someday!
neZZr is offline   Reply With Quote Quick reply to this message
Unread 11-27-2006, 04:15 PM   #4
Yeti342
Misch 4x4 big boy brackets move the seat back 4".
http://www.misch4x4.com/bigboy_brackets.html
Yeti342 is offline   Reply With Quote Quick reply to this message
Unread 11-27-2006, 04:16 PM   #5
Flipside
They're called "Big Boy Brackets" and they're made by Doug Misch.
Flipside is offline   Reply With Quote Quick reply to this message
Unread 11-27-2006, 04:35 PM   #6
The Zombie
Junior Member
The Zombie's Avatar
SOLVED SOLVED SOLVED SOLVED SOLVED SOLVED SOLVED SOLVED
You guys are studs, just bought big boy bracket, time since poted 3o minutes. that is amazing, you guys are amazing.
Unread 11-27-2006, 04:47 PM   #7
TJted33
im 6'6" and sit comfortably in the stock location
TJted33 is offline   Reply With Quote Quick reply to this message
Unread 11-27-2006, 05:15 PM   #8
BlueFlame
Me too @ 6 4" Do you whack your knees?
I cannot figure out how anyone could possibly hit their knees on the dash, but a lot seem to. Tall or short alike...
BlueFlame is offline   Reply With Quote Quick reply to this message
Unread 11-27-2006, 05:20 PM   #9
TJted33
nope, my knees dont touch. i have an aftermarket theft chip that sits right where my leg goes by the dash, it hits that every once in a while and knocks it out... leaving me questioning why my jeep doesn't start.
Unread 11-27-2006, 06:37 PM   #10
eclipse27
Im 6'5 and i sit fine...i just recline the seat back alil and kinda lean back. I actually find it quite comfortable.
eclipse27 is offline   Reply With Quote Quick reply to this message
Unread 11-27-2006, 06:57 PM   #11
Bigbob
I'm 6'6" and moved my seat back 2" and I'd still like to move it back another 1" or so. My problem is my head hits the stupid rollbar now. I need to figure a way to lower it 1"-1 1/2" or so. Bob
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline   Reply With Quote Quick reply to this message
Unread 11-27-2006, 07:17 PM   #12
Bruce The Moost
Maybe he is just more "leg" tall compared to "torso" tall, if that makes any sense at all. I'm 6'2" and my dad is 6'4", but I 'm taller than him when sitting because my torso is longer.
Bruce The Moost is offline   Reply With Quote Quick reply to this message
Unread 11-28-2006, 09:54 PM   #13
XJeffro
I am also 6' 6" and I don't have a problem with banging my knees in my 99 TJ. I am evenly proportioned and have no trouble.
I actually have more head room in the TJ than I did in my XJ. Although, I wouldn't mind seeing what the ride was like with a 2 or 4 inch seat relocation...
Silver 2005 Rocky Mountain Edition TJ, D44, 33" MT MTZ black steelies, 3" BDS Lift, BDS Ultimate Discos, Air horn, Hella 500s mounted on windshield w/KC mounts, Xenon 6" sport flares, Fabtech Rear Corners
LETS GO PENS!
HERE WE GO STEELERS!!
XJeffro is offline   Reply With Quote Quick reply to this message
Unread 10-29-2013, 09:32 PM   #14
mustangwarrior
sorry to revive an old thread, but i'm 6'5", 280lbs and i'm tired of having bent knees in my WJ, found this thread just lurking around and i don't know how any of you say you are 6'4" and fit fine in a TJ, my buddy had one and he is 5'10" and drove with the seat all the way back, i sat in it once and that was the first and last time i ever sat in the drivers seat, passenger side lacked serious space too, sucked on long trips
KCCO! -Nick
2001 Jeep WJ, I6, Select Trac, IRO 3", Cooper ST maxx 265-75, 16" Raceline Rockcrusher Wheels, Custom Tire carrier, 30" Seward LED Light bar, rear Aussie Locker
mustangwarrior is offline   Reply With Quote Quick reply to this message
