Quantcast Here is what I'm having trouble removing (mainly cause I don't know what it is) - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Here is what I'm having trouble removing (mainly cause I don't know what it is)
Old 07-24-2006, 02:16 AM   #31
TruckMuddr
Always Something
TruckMuddr's Avatar
I'd say if you really wanna remove it, I'd find a spot where it would fit and extend all the lines and wires. that way it is out of the way and still functioning.
Also, not sure about where you live, but I know here it's illegal to remove/disable the ABS system on a vehicle that came with it.
EDIT: Just read your post above. If your just removing it to make room for the mod, then reinstalling it, Then I don't see a problem in doing so. Most likely you will have to rebleed the ABS system, which is something different then bleeding the brakes.
EDIT #2: I just looked on All-Data and it says that you have to have a scan tool to bleed the brakes with abs.
STANDARD PROCEDURE - BLEEDING ABS BRAKE SYSTEM
ABS system bleeding requires conventional bleeding methods plus use of the DRB scan tool. The procedure involves performing a base brake bleeding, followed by use of the scan tool to cycle and bleed the HCU pump and solenoids. A second base brake bleeding procedure is then required to remove any air remaining in the system.
  1. Perform base brake bleeding.
  2. Connect scan tool to the Data Link Connector.
  3. Select ANTILOCK BRAKES, followed by MISCELLANEOUS, then ABS BRAKES. Follow the instructions displayed. When scan tool displays TEST COMPLETE, disconnect scan tool and proceed.
  4. Perform base brake bleeding a second time.
  5. Top off master cylinder fluid level and verify proper brake operation before moving vehicle.
Richard Harvey Jr.
'04 TJ, X, 4.0, Auto, Silver, D30/D44 w/LS & 4.56's, RC 4" Series II, PA 3" BL, Advanced Adapter's TC Bracket, 15x12 Eagle Alloys 058, 15/35-15 TSL, 4x K/C DayLighters & Windshield Mounts, Ventvisor's Bugsheild, Door Sill & Window Vents, Fabtech Front Bumper & homemade Rear W/ Backup Lights, Hurculiner.
On-Going Picture Thread
"It's Always Something And It's Never Good" - TruckMuddr
TruckMuddr is offline   Reply With Quote
Old 07-24-2006, 03:22 AM   #32
Poor Boy
All Around Nice Guy
Poor Boy's Avatar
i hate to have to say this...but if you absolutly need to disconnect those and pull them out, you should have your rig dragged to a brake shop to set your ABS back up. it's just too vital a system to not be done properly. i'm not mechanically retarded, but i am in no way confident enough to do anything except extended brake lines/standard maintenance in my drive way on my only real stop capability..
Originally Posted by Hank Venture
It's like someone with a fever is yelling at my pants!
Feed my girlfriend.
Follow my girlfriend
Brew what you drink, drink what you brew
USN Hull number 54
Poor Boy is offline   Reply With Quote
Old 07-24-2006, 03:41 AM   #33
GreenDean
Originally Posted by NEWtoTHEjeepLIF
Is the aluminum box just a bad to remove? Would it cause as much problems to re-connect? Really the main reason it needs to come out is so I can mod the fender and the support bracket. It will be going in about the same place as where it came out.
If you remove the ABS unit you are opening up a can of radio active worms if your not completely sure of what your doing.
ABS brakes are a royal pain in the booty.
There are many vavles, chambers, and selenoinds in that little thing that if you dont bleed the brakes right, your jeep will never stop correctly. And then you'll just have to bring it to a shop so they can do it with a vacuum pump. It's a pricey repair.
Do everything you can to work around it. Not on it.
GreenDean is offline   Reply With Quote
Old 07-24-2006, 07:49 PM   #34
NEWtoTHEjeepLIF
It required a bit more cutting but I think I have actually found a way to keep both of those items exactly where they were, even during the mod process. Thanks for all the help after the slow start.
Pics will come if I get it done tonight. If not they will come as soon as it's done.
NEWtoTHEjeepLIF is offline   Reply With Quote
Old 07-24-2006, 08:31 PM   #35
MT3Geiger
Yes Yes we all know that I am going to remove these parts and then go flying down a side street killing little children willy nilly until I get to a point where there are no more kiddies to kill then I will find a brick wall and head right for it. Also If you missed my other threads I removed my seats and seat belts. I drive on a five gallon bucket. I also removed my airbags. It will be a crazy trip and I will make sure to ask some one to hold my beer first. Geez where were you with all this helpful advice when I tried to drive down the freeway at 70mph with no rear shocks and no bolts connecting my hardtop?
I just shot milk outta my nose. I'm keeping that one.
2005 Silver Rubicon, 6 speed, Dual Tops + bikini,
2" BB, 1" BL, 33x12.5x16 Boggers, Cobra 75, KC 130W slimlights, OR Fab Rock Doors, and some poison spyder diff guards
MT3Geiger is offline   Reply With Quote
Old 07-24-2006, 11:43 PM   #36
NEWtoTHEjeepLIF
I worked around the two brake parts and lifted the fender on the driverside. The brake system stayed exactly where it was (which won't be a problem cause I am stretching the front axle forward a couple inches and that will provide even more room.
Here is a close up of the part sticking through.
Here is a shot from the side to show what it looks like sticking out. It will be covered with some sort of shield.
Old 07-25-2006, 12:50 AM   #37
103
Yeah, I was gonna say, regardless of the fact that messing with ABS is annoying, where was the need to move it? And even if you needed to move it, couldn't you just have moved it out of the way without disconnecting anything? I did that with the ABS on my Mustang back when I had to do an engine swap--worked fine. Zippie ties rock.
Wishing I had time to find a trail. I'd settle for driving on the beach. :(
103 is offline   Reply With Quote
Old 07-25-2006, 02:03 AM   #38
adp5025
If you want to live, dont fool with the brakes
1999 Jeep Wrangler Sport 4.0L 5 Speed (Dana 30/186MM Front Axle,3.73 Axle Ratio,Dana M35/194MM Rear Axle)
2004 Jeep Grand Cherokee OVERLAND 4.7H.O. V8
2007 Toyota Tacoma Double Cab 4.0L V6 TRD offroad
[COLOR="Blue"][B][FONT="Franklin Gothic Medium"]Penn State University - Engineering[/FONT][/B][/COLOR]
adp5025 is offline   Reply With Quote
Old 07-25-2006, 01:31 PM   #39
Dcomf
That's an ASNeR: Acute Spontaneous Nasal Reflux.
Dcomf is offline   Reply With Quote
Old 07-25-2006, 01:46 PM   #40
The Mean Fish
The amount of work you're putting into this is amazing, it's like watching my dogs try to get a treat out of a clear plastic container.
The Mean Fish is offline   Reply With Quote
Old 07-25-2006, 02:37 PM   #41
JerDog53
that shut them up
JerDog53 is offline   Reply With Quote
Old 07-25-2006, 03:05 PM   #42
Max1775
Not to worry. ABS is far less complicated than rebuilding an electronic automatic transmission... We've all done that, right? Right? Anyone?????? Hello, is this thing on?????
05' Rubicon Unlimited, 33" BFG M/T's
[CENTER][SIZE="5"][COLOR="DarkRed"]SAW 'EM OFF![/COLOR][/SIZE][/CENTER]
Max1775 is offline   Reply With Quote
Old 07-25-2006, 03:57 PM   #43
NEWtoTHEjeepLIF
I really don't know what that meant. It is alot more work than a simple flat fender but I think it should be worth it.
Old 07-25-2006, 04:04 PM   #44
UTWeezul
Glad to see you got that fender move taken care of. I'm interested to see what the finished product looks like
Enjoy life to the fullest each and every day!
http://www.midsouthjeeps.com/
UTWeezul is offline   Reply With Quote
Old 07-25-2006, 04:05 PM   #45
Dhorn33
When I swapped axles I just left the ABS piece alone and bled the brakes like normal after I installed the axles and the new ZJ proportioning valve. It has been working fine for more than 2 years now. Unhooking the brakes and reinstalling isn't rocket science?
Dhorn33 is offline   Reply With Quote
Glock Forum
