herculiner Q's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > herculiner Q's
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 08-07-2006, 07:34 PM   #1
superman613
herculiner Q's
I'm about to start the herculining process on my jeep but i had a couple questions:
1) What should I do about the bolts in the "bed" of the jeep that are painted over? (there are two on the passenger side)
2) How long do I wait before i remove the masking tape and bolt hole fillers?
3) Any other tips?
THANKS GUYS!!
Tommy T.
'98 Wrangler SE (yea that's right, four-banger)
5 speed tranny
33x12.50R15 MT/R's
15x8 Cragar Soft 8's
Explorer ProComp 2" suspension lift
1.75" BB lift on top of that
BL/MML coming soon to a Jeep near you!!
[COLOR=white]White Jeep Member #613[/COLOR]
superman613 is offline   Reply With Quote Quick reply to this message
Unread 08-07-2006, 07:37 PM   #2
Erik T.
I have another question also.
I'm wanting to herculine my stinger, it's powdercoated. I'd rather do it myself - any tips?
(Answer his first if you can though since I'm breaking into his thread)
-Erik.
Hack work? :rofl: You just described half the modified jeeps on this board.
Erik T. is offline   Reply With Quote Quick reply to this message
Unread 08-07-2006, 08:33 PM   #3
JeepRevolution
2005 WK
I'm not sure of what bolts, but if you dont plan on taking them out, go over them. For all your other holes use earplugs, works GREAT. I waited until about half way through the cure on my second coat, jsut a little bit tacky so it would hold the tape.
Tips:
PREP PREP PREP, its your most inportant part. Use the earplugs and go over everything 3 times to make sure you got everything. That and be ready for along day! Good Luck!
JeepRevolution is offline   Reply With Quote Quick reply to this message
Unread 08-07-2006, 08:41 PM   #4
bdf1783
were thier is alot of foot were i would do more than three coats i put three on my drivers side and were my foot rubs on the floor near the gass pedal it is allready worn off it was about 3 weeks old . o ya deff wear long sleeves and gloves i didnt and it took like 4 days for it to come off i didnt take the warning seriously and i payed for that got to a piont were i almost used a wire brush i was so agervated good luck post some pics after
bdf1783 is offline   Reply With Quote Quick reply to this message
