Help with uneven sway bar disconnects and leaning jeep. - JeepForum.com
post #1 of 35 Old 03-02-2014, 04:38 PM Thread Starter
timothywrsham
Hey guys, I need some help and advice. My jeep has been leaning to the driver side for some time now. I installed a OME 2.5in lift a few years ago and made sure to install the A and B coils correctly. The front driver side and rear passenger side received A coils while front pass and rear driver got the B coils. This arrangement made the rear passenger side about 1in higher and front passenger .5in higher. This seemed wrong to me since I always heard that the front driver side is supposed to be higher to accommodate for driver weight. (I have a left hand drive version btw).
Yesterday I decided to switch the real coils around after doing some searching on the forums. The rear driver side is now 3/16in lower than the rear passenger. The front Driver side is now .5in higher than the passenger side.
Unfortunately, while trying to readjust my sway bar disconnects I noticed that the passenger side was 1in-1.5in shorted than the driver side. What could cause such a larger difference? I dont think my sway bar is bent but it might be. My body mounts also look old and worn out, not exactly helping matters. They also look tweaked. Does anyone have any tips on where to measure the jeep for the most accurate readings? Would swapping the front A and B coils level out the jeep? Im most concerned about my sway bar links. That much difference cant be good.
Here are some photos to help you guys get the picture. The body mount pictures are on the passenger side and it looks like the body shifted forward over the frame. Would a new daystar body lift with replacement bushings help?
Passenger body mounts
Driver side frame
Passenger side frame
Front Sway bar
timothywrsham is offline
post #2 of 35 Old 03-02-2014, 10:13 PM Thread Starter
timothywrsham
No One?
post #3 of 35 Old 03-02-2014, 10:41 PM
mukluk
Let's see, passenger side sway bar link ends up shorter than the driver's after adjusting on level ground and passenger side body mounts appear shifted... the Jeep has been hit in the past maybe? Possibly a bent or twisted frame?
To answer your second question, no, installing a body lift won't realign the body with the frame mounts.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #4 of 35 Old 03-02-2014, 10:42 PM
rug_15
Well. That all sounds silly to
Me. One size spring on one side? Different on the other? Makes no sence. Front and rear? Maybe? Anyways. I'd get new springs. Start with that. You can get decently cheap ones online. Might level you out. Your body mounts are from frame to body... And arnt affecting anything from where you are measuring... And they shouldn't affect your away bar either. So. No need to worry about those. Hope this helps!
rug_15 is offline
post #5 of 35 Old 03-03-2014, 10:19 AM Thread Starter
timothywrsham
It was involved in head on collision at 40mph in 2007. Stayed at the dealership all summer though getting repaired (other drivers fault so they paid the bill). I still think they did a half *** job fixing it. Old man emu springs are different lengths to handle engine torque. Maybe I received mislabeled springs. Is there anyway to check if the frame is bent easily?
post #6 of 35 Old 03-03-2014, 10:24 AM
JBTJ
There is your problems. I wouldn't worry about tub part, but I would have the correct length coil springs on both sides. Engine torque has nothing to do with your springs.
JBTJ is offline
post #7 of 35 Old 03-03-2014, 11:01 AM
JStMarie
JStMarie's Avatar
Different size springs for driver weight; engine torque.
Someone is blowing smoke up your ... ahem. I think you've been misinformed and as a result may have installed your lift incorrectly.
JSt.Marie
'06 Jeep Wrangler, 65th Edition, stock.
'98 Jeep Wrangler, stock.
JStMarie is offline
post #8 of 35 Old 03-03-2014, 11:17 AM
rouxbicon
http://arbusa.wordpress.com/2011/02/...fitting-guide/
'03 red Rubi
rouxbicon is offline
post #9 of 35 Old 03-03-2014, 11:32 AM
JStMarie
JStMarie's Avatar
Open mouth, insert foot.
Sounds a bit illogical to me, given the jeep is a passenger vehicle (and passengers aren't typically weightless), but hey there must be more involved there than meets the eye (my eye anyway).
Teach me to chime in on subjects I know too little about.
JSt.Marie
JStMarie is offline
post #10 of 35 Old 03-03-2014, 11:46 AM
JBTJ
Typical British BS. Wonder why the are the only company in the world to do that? They would be up S creek if someone bought into this and weighed more than they figured. Can you say leaning tower of Pisa.
JBTJ is offline
post #11 of 35 Old 03-03-2014, 12:33 PM
Vinman
You do realize since OME is an Australian company their reference to driver and passenger sides are opposite to North American drivers and passenger sides, right?
Vinman is offline
post #12 of 35 Old 03-03-2014, 01:12 PM
athos76
Not really sure about the logic here.. Doesn't matter which side the driver's side of the vehicle is on, as long as the corresponding coil goes along with it.
2006 I6 6-Speed X, 33" Goodyear Duratrac, 8.8.
athos76 is offline
post #13 of 35 Old 03-03-2014, 01:54 PM
Robert J. yates
Post up pix of the body mounts from the other side. The 3 you put up already all look to leaning backwards which would be consistent with a head on collision. I'm guessing your tub is not square to the frame anymore because of that so IMO, you have bigger problems than what OME spring goes where. You should have pressed the insurance company to total the Jeep if this turns out to be the case.
Originally Posted by samgm2 View Post
And yes, I am an exceptional scientist and engineer.
Robert J. yates is offline
post #14 of 35 Old 03-03-2014, 03:46 PM
Jeepinty
British eh? As mentioned OME is an Australian company and makes great stuff (albeit a bit on the expensive side).
I may be mistaken but I believe the difference is made via spring rate but can make a slight difference in unloaded spring height.
For what it's worth Rough County did the same thing years ago so it's not as uncommon as you think.
http://www.rockcrawler.com/features/...ry_tjcoils.asp
Jeepinty is offline
post #15 of 35 Old 03-03-2014, 03:48 PM
Jeepinty
That's exactly the logic he is talking about although Rough Country's reason for doing this wasn't for compensating driver weight, it was to counter the body roll due to engine torque which they claimed wore springs out prematurely.
Jeepinty is offline
