Help Transmission Issue!!! - JeepForum.com
post #1 of 4 Old 10-07-2011, 09:58 AM Thread Starter
toddwill74
Hey guys! I have an issue and pretty much know I can count on yal for great advice. My '97 TJ 4.0 auto started giving me some issues yesterday. I was driving down the road and my transmission started slipping terribly. I pulled over and it would move a couple hundred yards and start slipping again. It would start at about where it was changing into 2nd gear.
Well while sitting on the side of the road I called two local auto parts stores. One was O'Reillys and the other was Carquest. The two that I somewhat trust in the charlotte area. They both gave me the same input not to change the fluid just add a quart of the Lucas No-slip to the tranny. Only change the fluid as a last result.
Well the No-slip didn't work. So, I went back today and changed the fluid and filter on the side of the road. I used ATF +4 and added a bottle of the Lucas No-slip for good measure. So when I was done I cranked my jeep and let it idle in neutral for a while and checked the fluid and shifted thru the gears and all seemed well. So I ventured to drive it home. It made it home just fine. I did notice it was a little different downshifting into 1st gear. Sometimes it acted like it didn't wanna go into 1st. So I figured the only way to test it out was to drive it. I was on my way to work and was probably 20 miles into my drive and it started doing the exact same thing.
So I guess my question now is NOW WHAT??? What do I do to it now? I know we all love our jeeps and I'm sure someone out there has had the same issue...
I love the forum and use it as the main source of advice. Thanks in advance!
toddwill74 is offline
post #2 of 4 Old 10-07-2011, 12:03 PM
JBTJ
First off I'd never use that Lucas crap. Second, since you already changed the filter and fluid it could just be you need a new tranny. But since you only dropped the pan to change the filter that was only 3 quarts of the 12, or is it 9, I don't recall right now, that's in the system. I'd change ALL the fluid which includes what's in the torque converter then go from there. There are several write-up's including what I've posted that tells you how to do that. BTW those auto parts house guy’s know just enough to be dangerous.
JBTJ is offline
post #3 of 4 Old 10-07-2011, 08:46 PM
joe108
I hate trannies problems, they either work or you have to take them to be rebuilt , hope the fluid change fixes it.
joe108 is offline
post #4 of 4 Old 10-09-2011, 01:33 PM Thread Starter
toddwill74
Ok thanks guys! I have saw postings about adjusting the bands. I didn't know what I should do. Money is tight. Can't really afford the $2000+ for a rebuild so I will try anything.
tranny , tranny problem , transmission
Transmission issue Mishka1324 YJ Wrangler Technical Forum 7 07-11-2011 04:44 AM
Transmission issue thatnameisinuse TJ Wrangler Technical Forum 4 07-25-2010 12:27 PM
Transmission issue zfender14 YJ Wrangler Technical Forum 2 10-22-2009 10:40 PM
transmission issue ? drive shaft issue ? clutch issue..where to begin ?..... rthompson48082 YJ Wrangler Technical Forum 7 09-28-2009 05:07 PM
Transmission Issue--Please Help!! hondurena YJ Wrangler Technical Forum 2 12-25-2008 01:30 PM
