Help with transfer case leak - JeepForum.com
post #1 of 13 Old 06-28-2013, 04:54 PM Thread Starter
dougiefresh131
Hi all,
I have a leak in my transfer case. It is leaking from a tiny hole almost right above the transmission mount. It has been leaking for some time and it was only just recently that I took the skid plate off to get a better look.
In the picture you can see fluid beading up and the hole it is coming from directly above it.
dougiefresh131 is offline
post #2 of 13 Old 06-28-2013, 04:58 PM
Randonexplosion
Deplorable
Randonexplosion's Avatar
So that would mean that your transission is leaking and running down onto your t-case?
Randonexplosion is online now
post #3 of 13 Old 06-28-2013, 06:09 PM
jeepmutiny
1983 CJ7
Yup rear trans seal it looks like, not too big a deal to fix. With the skid off your half way there...Jon
jeepmutiny is offline
post #4 of 13 Old 06-28-2013, 11:36 PM Thread Starter
dougiefresh131
Ok. Is the little hole where the fluid is coming from supposed to be there? What is its purpose?
Any more info about the rear trans seal?
post #5 of 13 Old 06-28-2013, 11:43 PM
Randonexplosion
Deplorable
I was wondering that as well. Maybe it is a failsafe so you will notice it before your trans fluid gets too low and it overheats?
post #6 of 13 Old 06-28-2013, 11:48 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Yes.
To let you know it's leaking.
Do you have an OEM FSM?...
Knuckelhead is offline
post #7 of 13 Old 06-28-2013, 11:54 PM
Randonexplosion
Deplorable
Yay im smart...
post #8 of 13 Old 06-29-2013, 12:05 AM
Knuckelhead
AFSOC Retired
Yay im smart...
It also lets the adapter between the transmission and the transfer case remain at ambient pressure...
post #9 of 13 Old 06-29-2013, 12:07 AM
Randonexplosion
Deplorable
That makes sense. I dont think my AA adapter has one, maybe it would be a good idea to drill a small hole.
post #10 of 13 Old 06-29-2013, 12:15 AM
Knuckelhead
AFSOC Retired
What AA adapter are you referring to?...
post #11 of 13 Old 06-29-2013, 12:21 AM
Randonexplosion
Deplorable
4l60e to np231. I need to take a closer look but im almost positive there is no "weep" hole.
post #12 of 13 Old 06-29-2013, 12:23 AM
Randonexplosion
Deplorable
Though I remember during WhyJs engine swap thread he noticed trans fluid leaking through the adapter due to a seal on the trans side that he didnt install. So I would probably notice it without a hole.
post #13 of 13 Old 06-29-2013, 06:08 AM
yachtman
Morning, yes your tranny output shaft seal is leaking, very common.
Drop front and rear shafts.
I don't drain tranny fluid, just have a pan rady.
There are 6 nuts on the transfer case 9/16's, the top 2 are tricky. They are a breeze if you pull the center console and the shifter, if its an automatic. Either way, no big deal, the top 2 are just a hassle.
Put a rolling jack under the TC, makes it allot easier.
Disconnect the TC linkage, screwdriver and pop it off.
Disconnect a few electrical connections on top of the TC case.
Pull the TC out.
Pull the tranny seal.
While its apart, replace the TC seal as well. Seals are less than $10 each.
Takes about 4 hours the first time. It's not hard just takes some time.
There are plenty of really good posts on the process.
Good luck.
yachtman is offline
case , leak , transfer , transmission
