-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Help with transfer case leak (http://www.jeepforum.com/forum/f9/help-transfer-case-leak-1542541/)
dougiefresh131 06-28-2013 04:54 PM
Hi all,
I have a leak in my transfer case. It is leaking from a tiny hole almost right above the transmission mount. It has been leaking for some time and it was only just recently that I took the skid plate off to get a better look.
In the picture you can see fluid beading up and the hole it is coming from directly above it.
http://i981.photobucket.com/albums/a...psbf069969.jpg
Randonexplosion 06-28-2013 04:58 PM
So that would mean that your transission is leaking and running down onto your t-case?
jeepmutiny 06-28-2013 06:09 PM
Yup rear trans seal it looks like, not too big a deal to fix. With the skid off your half way there...Jon
dougiefresh131 06-28-2013 11:36 PM
Ok. Is the little hole where the fluid is coming from supposed to be there? What is its purpose?
Any more info about the rear trans seal?
Randonexplosion 06-28-2013 11:43 PM
I was wondering that as well. Maybe it is a failsafe so you will notice it before your trans fluid gets too low and it overheats?
Knuckelhead 06-28-2013 11:48 PM
Yes.
To let you know it's leaking.
Do you have an OEM FSM?...
Randonexplosion 06-28-2013 11:54 PM
Yay im smart...
Knuckelhead 06-29-2013 12:05 AM
Originally Posted by Randonexplosion (Post 15620289)
Yay im smart...
It also lets the adapter between the transmission and the transfer case remain at ambient pressure...
Randonexplosion 06-29-2013 12:07 AM
That makes sense. I dont think my AA adapter has one, maybe it would be a good idea to drill a small hole.
Knuckelhead 06-29-2013 12:15 AM
What AA adapter are you referring to?...
Randonexplosion 06-29-2013 12:21 AM
4l60e to np231. I need to take a closer look but im almost positive there is no "weep" hole.
Randonexplosion 06-29-2013 12:23 AM
Though I remember during WhyJs engine swap thread he noticed trans fluid leaking through the adapter due to a seal on the trans side that he didnt install. So I would probably notice it without a hole.
yachtman 06-29-2013 06:08 AM
Morning, yes your tranny output shaft seal is leaking, very common.
Drop front and rear shafts.
I don't drain tranny fluid, just have a pan rady.
There are 6 nuts on the transfer case 9/16's, the top 2 are tricky. They are a breeze if you pull the center console and the shifter, if its an automatic. Either way, no big deal, the top 2 are just a hassle.
Put a rolling jack under the TC, makes it allot easier.
Disconnect the TC linkage, screwdriver and pop it off.
Disconnect a few electrical connections on top of the TC case.
Pull the TC out.
Pull the tranny seal.
While its apart, replace the TC seal as well. Seals are less than $10 each.
Takes about 4 hours the first time. It's not hard just takes some time.
There are plenty of really good posts on the process.
Good luck.
The time now is 09:24 PM.
