Help with trailer hitch - JeepForum.com
post #1 of 11 Old 07-28-2010, 09:24 AM Thread Starter
Joeggernaut
Ok I know there is a towing hitch section but it seems more geared to towing jeeps than jeeps actually towing and I figure tj tech would know more.
Anyways I want to buy a class 3 rear trailer hitch to pull a jet ski (only about 1000lbs). I have a 2000 sahara 4.0l 5 speed.
It needs light hook ups but I dont know where you would install the adapter. I looked last night and there is a uhaul light cable that is inside the tub hidden under the carpet and threaded to the back near the spare. Is this stock or did the po have this in? Can I use it anyway and if not what do I need?
(I want a 6 round to a 4 flat light adapter)
Also some of the tow hitches are straight and some are bent, what gives?
If you could recommend a decently priced hitch. Like 100-150 bucks that includes the light adapter.
Joeggernaut is offline
post #2 of 11 Old 07-28-2010, 09:28 AM
KEH1997
The wiring harness plugs into the light wiring behind the two taillights. Beneath the tub right under the taillights, there should be a black plastic flap covering the lower corner of the tub. Just pull that flap out (a flat-head screwdriver helps) and reach your hand up in there. You'll feel a wiring adapter wrapped with a soft cushion-type thing. Unwrap that and plug your wiring harness in between. Repeat for the other side of the vehicle. Then you just run the wiring harness down to the back bumper and you're set!
Do a Google search for a more detailed write-up. It's really easy...
KEH1997 is offline
post #3 of 11 Old 07-28-2010, 09:28 AM
keithert
keithert's Avatar
I got my light adapter from a local hitch store for $23. The hookups for it are under the tub behind the tail lights. There are access flaps under the Jeep by the plastic bumper ends.
I got my hitch used on Craigslist.
Current: 2016 Ram 1500 Sport - Past: 05 Wrangler LJ, 90 and 92 Trackers and 98 Wrangler SE
keithert is offline
post #4 of 11 Old 07-28-2010, 09:30 AM
KEH1997
Here's the one I got: 1997 Jeep Wrangler Custom Fit Trailer Wiring Harness | etrailer.com. It works just fine, and it came with a full set of instructions that were very easy to follow.
KEH1997 is offline
post #5 of 11 Old 07-28-2010, 09:32 AM Thread Starter
Joeggernaut
ok thanks so that uhaul light adpater i have is not stock then? also kinda off topic but is there a factory jack and if so where would it be/stored.
I just go the thing 2 days ago. So im nooby and I did google and saw a vid on installation but I wasnt sure what the uhaul light is for.
I see that harness is for 4 flat pole
but what about a 6 round one for different trailers.
edit: nevermind I get it now. noob moment.
post #6 of 11 Old 07-28-2010, 09:39 AM
KEH1997
The U-Haul one must be aftermarket.
The factory jack is stored under the passenger's seat. There's a place it slides into, and a strap that wraps over it.
KEH1997 is offline
post #7 of 11 Old 07-28-2010, 09:40 AM Thread Starter
Joeggernaut
thanks I would of never guessed to look there.
post #8 of 11 Old 07-28-2010, 09:45 AM
Coop02x
If your interested, I have a class III Quality S hitch I am looking to get rid of. Its yours for $50 OBO plus shipping on your dime. I can even ship it to you or you can come pick it up if the drive from NC isn't too bad. Let me know if your interested.
I have pics and so forth if you want them. The only reason I took it off was bc I bought a Ground Pounder Fab. rear bumper/tire carrier that had a receiver.
Coop
Coop02x is offline
post #9 of 11 Old 07-28-2010, 09:50 AM
KEH1997
^^ Do it!
KEH1997 is offline
post #10 of 11 Old 07-28-2010, 10:18 AM Thread Starter
Joeggernaut
send me a pm with some pics please =)
post #11 of 11 Old 07-28-2010, 11:50 AM
Coop02x
PM sent! Hopefully the pics will show up. Let me know if the don't and I will try again!
Coop
Coop02x is offline
trailer , hitch , lights , harness , hook up , tj , wrangler , towing
Which Trailer Hitch for TJ cntp TJ Wrangler Technical Forum 75 05-23-2014 02:00 PM
Which Trailer Hitch? Spagent TJ Wrangler Technical Forum 16 08-18-2011 11:35 PM
Trailer Hitch? bjjfoshizzy TJ Wrangler Technical Forum 9 10-29-2009 10:22 PM
trailer hitch help thesherm TJ Wrangler Technical Forum 14 07-20-2006 02:36 PM
trailer hitch hondatech YJ Wrangler Technical Forum 11 05-02-2003 03:48 PM
