Help - TJ won't start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Help - TJ won't start
Nitro Gear Packages Now Available at Rockridge 4wdJEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFFThe ULTIMATE "Selectable" Locker System! Brough
Unread 09-10-2011, 12:46 PM   #1
brettbittner
Hello, I searched through the forum and didn't see anything addressing my issue, so I am hoping someone could help. My TJ won't start ('02, manual, 4.0L). The key turns, the dash lights up, the A/C kicks on, but no joy under the hood. I have swapped out the starter, tested the battery, tested the starter relay, and even tried jumping it for the fun of it. Still nothing.
Background - I've had the Jeep for ~2 months; this started happening a week and a half ago, but it eventually started. Has been going downhill this week and now no matter how many times I try it still won't start.
Any ideas?
Thanks, Brett
brettbittner is offline   Reply With Quote Quick reply to this message
Unread 09-10-2011, 12:53 PM   #2
flying_bosun
The clutch safety switch is probably shot. It's on the clutch push rod under the dash, the plastic cylinder with two wires. You can clip the wires and butt connect the live ends together or install a momentary switch if you want to keep the safety cut-off working.
There may also be a fuse behind the glove box that you can pull to disable it, but I'm not sure about that, much less which fuse it would be. Just think I remember someone else mentioning it in another thread.
[URL="http://www.grimmjeeper.com/gears.html"][COLOR="Red"][SIZE="3"]Gear-Calculator[/SIZE][/COLOR][/URL] [URL="http://www.stu-offroad.com/siteindex.asp"][COLOR="White"][SIZE="3"]Stu Can Help You[/SIZE][/COLOR][/URL] [URL="http://www.berrysprinter.com/jeepparts.php"][COLOR="Blue"][SIZE="3"]Part Names and Numbers[/SIZE][/COLOR][/URL] [URL="http://www.wholesalemopar.com/"][SIZE="3"][COLOR="Red"]Dealer Supplied Parts and ask for "Jeep Club" Prices[/COLOR][/SIZE][/URL]
[QUOTE=Ron Paul]“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul[/QUOTE]
[CENTER][SIZE="5"]"Did [I]you[/I] exchange your walk-on part in the war for a lead role in a cage?"[/SIZE][/CENTER]
flying_bosun is offline   Reply With Quote Quick reply to this message
Unread 09-10-2011, 01:15 PM   #3
brettbittner
flying bosun, you are me new best friend!!! I threw a spare (well it looked like a spare) fuse in the slot to override the clutch safety switch and it started right up!! Thanks, you made my day.
Brett
start problems , tj
