Help - TJ won't start - JeepForum.com
post #1 of 3 Old 09-10-2011, 11:46 AM Thread Starter
brettbittner
Hello, I searched through the forum and didn't see anything addressing my issue, so I am hoping someone could help. My TJ won't start ('02, manual, 4.0L). The key turns, the dash lights up, the A/C kicks on, but no joy under the hood. I have swapped out the starter, tested the battery, tested the starter relay, and even tried jumping it for the fun of it. Still nothing.
Background - I've had the Jeep for ~2 months; this started happening a week and a half ago, but it eventually started. Has been going downhill this week and now no matter how many times I try it still won't start.
Any ideas?
Thanks, Brett
brettbittner is offline
post #2 of 3 Old 09-10-2011, 11:53 AM
flying_bosun
The clutch safety switch is probably shot. It's on the clutch push rod under the dash, the plastic cylinder with two wires. You can clip the wires and butt connect the live ends together or install a momentary switch if you want to keep the safety cut-off working.
There may also be a fuse behind the glove box that you can pull to disable it, but I'm not sure about that, much less which fuse it would be. Just think I remember someone else mentioning it in another thread.
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #3 of 3 Old 09-10-2011, 12:15 PM Thread Starter
brettbittner
flying bosun, you are me new best friend!!! I threw a spare (well it looked like a spare) fuse in the slot to override the clutch safety switch and it started right up!! Thanks, you made my day.
Brett
start problems , tj
Cold Start Turned Into No Start...Problem Resolved...Lesson Learned... tony673 YJ Wrangler Technical Forum 2 10-02-2011 07:49 PM
Can you push start / bump start a TJ? (posts from Boonie Mechanic tricks thread) Wheelin98TJ TJ Wrangler Technical Forum 162 02-08-2011 11:50 PM
Rough idle at start question....opinion before I start spending money. Cali04LJ YJ Wrangler Technical Forum 1 08-23-2010 10:07 AM
Jump start = Volt Meter spikes while driving then wont start AWILD TJ Wrangler Technical Forum 5 02-21-2010 05:37 PM
1997 2.5 will not start on incline and rough start/idle when cold. BuckeyeTJ TJ Wrangler Technical Forum 0 11-24-2009 09:39 AM
