HELP TJ wanders all over the road?? - JeepForum.com
post #1 of 13 Old 02-09-2006, 07:20 AM Thread Starter
tlsmith22
I bought a 97 TJ and don't know alot about it. It has a 4 " trailmaster lift and 33's. I have replaced the steering box and it has new tires. It still wanders on the road quite a bit. It has the factory track bar and it appears worn bad to me. Could this be causing this problem? I am going to replace the track bar with an adjustable pretty soon. Is there anything else I can look at to find the problem? I don't know if it has a drop pitman or not, but it appears factory to me.
tlsmith22 is offline
post #2 of 13 Old 02-09-2006, 07:25 AM
fisher836
fisher836's Avatar
You should be ok with or without a drop pitman arm on 4" lift. I think you will find that your track bar is the culprit. Although, I would make sure everything's sured up all around (sawy bar, rear track bar) Is the rear track bar adjustable or does it have a relocation bracket or stock?
Definition of Rubicon:
A limit that when passed or exceeded permits of no return and typically results in irrevocable commitment.
fisher836 is offline
post #3 of 13 Old 02-09-2006, 07:26 AM
Kameel
Kameel's Avatar
Can be lots of stuff.. bad shocks, cheap tire brand, worn out bushings.
Trackbar replacement is a good thing to start with.
Instant human...just add coffee.
Kameel is offline
post #4 of 13 Old 02-09-2006, 07:46 AM
Muddeprived
Muddeprived's Avatar
You mentioned new tires. Check the pressure. Get em down to the 25-30 range since most tire shops never inflate them properly. An overinflated tire jumps all over the place.
I would consider the trackbar 2nd.
2001 XJ Sport 4.5" LA
1999 TJ 2.5L 5spd 2" lift
Muddeprived is offline
post #5 of 13 Old 02-09-2006, 07:51 AM
river rat
Forum porn star...I guess
river rat's Avatar
This statement couldn't be any further from the truth. If you're riding on only 4 inches of lift and you have a dropped pitman arm with out a track bar relocator bracket, you WILL NOT be ok. You will experience significant bumpsteer.
97 TJ. Full width D60 w/Detroit, Alloys and 5.89 gears. Full width D44 spooled, 60 outers, Warn lockouts. 6" Rock Krawler Gen II LA. 11 gallon cell behind the rear seat. 37" Maxxis Trepador competitions on 17" Stazworks double internals, blazay, blazay.....
river rat is offline
post #6 of 13 Old 02-09-2006, 07:56 AM
JPJeeper
1972 CJ5
I just did a lift install and somehow neglected to get the track bar all the way tight. My rig wandered all over the road. Tightened it up, and all was good.
On a side note, if you toe in (Alignment) isn't set properly it will also do the same thing.
2006 Unlimited Rubicon
1990 Wrangler YJ
1987 Wagoneer FSJ
1975 J20 Jeep Truck
1967 J3000 Jeep Truck
JPJeeper is offline
post #7 of 13 Old 02-09-2006, 07:58 AM
de6w6it
Either drop pitman arm and trackbar bracket, or just adjustable track bar. You have to keep drag link and track bar parralel to not experience bumpsteer.
Is the alignment ok? I think toe in could affect wandering....
To check the trackbar, have someone in the jeep turn the steering wheel back and forth while you look at the car head on from the front. If the axle/wheels shift relative to the body to the right or left, this could signify the trackbar being the culprit.
I would also check the steering links....
'66 Mustang/200/C4/ground up resto
'88 4 runner/SAS/22re/W56/duals/31's DD
Build:
de6w6it is offline
post #8 of 13 Old 02-09-2006, 08:05 AM Thread Starter
tlsmith22
I have done this, and the track bar moves up and down where it connects to the body. It seems to move up and down maybe an 1/8 or so. I torqued it to 70 ft lbs and it still does this. Is that a sign it is worn out. I am going to have it aligned as soon as I get a new track bar. It appears stock on the rear track bar to me.
post #9 of 13 Old 02-09-2006, 10:17 AM
meengineer2006
My Jeep did the exact same thing as you describe, and the ball joint on the trackbar was shot and all "warbled" out. I replaced the trackbar and the jeep drove like new.
meengineer2006 is offline
post #10 of 13 Old 02-09-2006, 10:34 AM
Steelman
IX-X-XIII-XIV-XL-XLIII
Steelman's Avatar
funny, every Jeep I've ever driven wandered all over the road to some extent!
-Bob
'98 Black TJ Sport 4.0L/Auto Trans
-(O|||||||O)-
my rig:
_____________________________________________
Originally Posted by _Trucker View Post
I would rather shoot you in the face than play a guessing game....
Originally Posted by mrblaine
Are you bipolar, passive agressive, or just unable to recognize the dichotomy of your thought processes?
Steelman is offline
post #11 of 13 Old 02-09-2006, 10:45 AM
xjeepn
xjeepn's Avatar
I put a 2" re bb lift and put 32" kumo on and it is all over the place. I hate this BB lift. Maybe it is the RE shocks. The cheap ones you know.
xjeepn is offline
post #12 of 13 Old 02-09-2006, 10:49 AM
igofshn
Locked @ both ends
igofshn's Avatar
I would start with the alignment. Easy and cheap. You can do it yourself in 5 minutes. Look in the FAQ (stickie at the top of the section).
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #13 of 13 Old 02-09-2006, 11:01 AM
dcafaro
I agree, you need the drop pitman arm to keep the geometry of each bar true to the other. At four inches you need to make sure you use all the extensions for them. Also if you went up to 33" tires your factory steering stabilizer is useless. I had to upgrade mine even at 32".
dcafaro is offline
jeep wanders to right between shifts ScottinPA TJ Wrangler Technical Forum 21 06-25-2009 03:03 PM
Advice on increasing on-road ride quality without sacrificing off road Lord_Xcalibur Wrangler General Discussion 15 12-15-2008 08:41 PM
The Jeep wanders with AFUCA's Chris @ GATR TJ Wrangler Technical Forum 12 07-25-2007 08:29 PM
Unlimited wanders in the rear. 1 Long CJ TJ Wrangler Technical Forum 2 03-23-2007 09:54 AM
jeep wanders ---- real bad. 1BadTJ TJ Wrangler Technical Forum 9 09-07-2006 10:50 PM
