Help on a TJ build - JeepForum.com
post #1 of 2 Old 02-20-2012, 07:37 PM Thread Starter
thedean06
Help on a TJ build
I've got a 06 TJ X Manual, and i am looking to do some stuff to it but I'm fairly new at this so i thought i would open it up to some experienced insight.
Im looking at a 4 inch lift for it. Im wondering if there is anything that i need to worry about breaking down early, or things that i would need to replace right out of the gate to make it run right? I think im going with the rough country N2.0 lift. Im not planning on doing any hard wheeling, and Im pretty poor, so Im going for a cheaper kit.
I already have 31 inch tires on it so i dont think im going to bump up the tire size. (for right now at least)
the other thing i was wondering about is gearing.
Right now I think the X model has 3.07's in it (the tag on the diff is a little beat up). and with the tires i have on, any hill in 6th gear is dragging me down fast. so I was wondering what gearing i would have to jump to, to get 6th gear working right again. I think that carrier cut off is 3.55's. and i'd like to keep the carrier to save some money. but if i need a new carrier, i guess i need a new carrier. i suppose if i do get bigger tires im gonna need higher gears for those too.
Any help is much appreciated!
thedean06 is offline
post #2 of 2 Old 02-20-2012, 10:50 PM
dcope17
4" lift requires a lot of extras so if you're pretty poor, this isn't the way to go. Several have done the Zone 3 3/4 combo lift... 2.5 suspension with the 1.25 body lift and are very happy. Do a motor mount lift and some longer front brake lines then possibly a small drop of the transfer case skid ( can be done with washers but mixed reviews of that ) and you're in business.
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
build , gears , lift , tj
Jeepbronco1 SUT build (my mini truck build) aka bobbed top jeepbronco1 JK Wrangler Technical Forum 251 05-08-2017 07:34 AM
200 tj build! it got totalled so goin to build it hewy885 TJ Wrangler Technical Forum 2 09-08-2010 05:50 PM
1998 TJ - 3 inch Hybrid build - Looking for suggestions & build review jmars TJ Wrangler Technical Forum 1 04-26-2010 07:36 AM
1998 TJ - 3 inch Hybrid build - Looking for suggestions & build review jmars TJ Wrangler Technical Forum 0 04-24-2010 08:50 AM
Build advice for a high-line type build The Rat YJ Wrangler Technical Forum 1 02-11-2009 02:21 PM
