HELP! Stripped torx bolts on window hinge - Page 3 - JeepForum.com
post #31 of 43 Old 05-08-2008, 03:09 PM
Fred99TJ
Welding it you have a risk of burning the paint or scratching it. That particular bolt can be drilled out and re-tapped then just use a Hex head SS Bolt.
Built 92 XJ For Sale
Fred99TJ is offline
post #32 of 43 Old 05-08-2008, 03:40 PM
Muddy_Nole
Same thing here, installing kongo kage. Driver's side no problem. Passenger side, I stripped them all. Broke two extractors and nearly had to be commited to the mental hospital.
Still under warranty, had the bright idea to take it to the dealreship. The body shop guys used an air chisel. Funny to see all the guys in the shop standing there looking perplexed. They gave me some line about the bolts really not meant to be removed and sent me on my way with some touch-up paint for the damage I did.
Needless to say impressed with the dealership.
BTW: the racks are excellent..just need to trouble shoot a squeak in my Yamika Low Riders
Muddy_Nole is offline
post #33 of 43 Old 05-08-2008, 03:47 PM Thread Starter
distantdog
If they werent meant to be removed, I think they should not use bolts. They should just weld the hinges on.
2004 WJ Laredo Special Edition V8 4x4
SOLD: 2001 TJ Sport
distantdog is offline
post #34 of 43 Old 05-10-2011, 07:05 AM
KevKaos
Stripped mine last night and had to resort to a screw extractor. Problem is the screw extractor snapped under hand pressure, so now I am screwed. Literally.
KevKaos
Honey Badger Wheelin'
RED JEEP CLUB # 621
It's not much, but check out my build thread;
Originally Posted by krashnpa View Post
I know kev was riding his tank skid and belly pretty good on some of the blacks up at RC, but he doesn't back down from the line either.
so I use my original nuts?
You should, in no way, take any of this personally. It's just business. So to recap, I come in peace, I mean you no harm, and you all will die. Gallaxhar out.
KevKaos is offline
post #35 of 43 Old 05-10-2011, 07:14 AM
p997c4s
Originally Posted by Deere9670 View Post
I dont have any experience with that method, nor do I own a dremal. I would like to try the welding the nut on method, but am worried about messing up the paint on the jeep. I know that during the summer with the mirror mover brackets in place it, will cover up any marks left on from welding aroud the area, but I am concerend about wither when the mirrors are back in there original place. Does anyone know if the weld will damage the paint around the bolts?
Do it, weld a nut on it. Here is my thread about removing all tailgate hinge bolts in less than an hour. http://www.jeepforum.com/forum/f9/wa...ff-1h-1207469/
The paint on the hinge right next to the bolt will get damaged though. In my case I wanted to sandblast the hinges and paint them black anyway. I have tried removing these bolts in every way described on this forum. This is my way and I will do it again next time. Good luck!
Sorry guys, this was an old thread.... .
p997c4s is offline
post #36 of 43 Old 05-10-2011, 09:05 AM
FastLearner
well i will say I had this same problem... been preoccupied making other modifications so havent come back to it yet... but I will say this... I only had this problem of the torx heads stripping on bolts that I did not remove the paint sealing the bolt to the winshield hinge. All the other bolts I made sure to carefully scrape the paint out of the gap before turning the bolt and the rest all came out no problem.
FastLearner is offline
post #37 of 43 Old 05-10-2011, 09:10 AM
sunnycool1
Gahhhhh!!!! I have this same problem! Is there a better kind of bolt that I can replace these stripped ones with when I finally get them out?
sunnycool1 is offline
post #38 of 43 Old 05-10-2011, 09:22 AM
1HouseMouse
Anyone reading this post in the future I hope this helps. I read many posts over this issue and how to get the Torx Bolts out without any damage to the bolt or Bit. Soooooo, I took what seemed to be the best of the best posts and proceeded as follows. First I placed my LJ in the direct sunlight to heat up the bolts. As I recall it was exposed for about four hours in the 90ish degree heat. Then I took my Torx Bit and adapted it to an 18" Breaker bar. I placed the Torx bit square and firmly into the Bolt. Then as I sweat my thoughts of the Bolt or Bit stripping out, I applied firm but steady pressure on the Breaker Bar. All the Torx Bolts were removed effortlessly. This is all thanks to all the Posts I have read concerning this subject. Most probably will not work in a colder climate unless external heat is applied? Maybe a Sun Lamp? Anyways, I did have a back up plan if had stripped out a Torx.
1HouseMouse is offline
post #39 of 43 Old 05-10-2011, 10:39 AM
MountainMan864
Drill a hole and hammer an ez-out in then attach it to the drill and back the stripper stupid torx out. Might have to put alot of pressure on it.
MountainMan864 is offline
post #40 of 43 Old 05-11-2011, 06:00 AM
KevKaos
Good idea, except my screw extractor broke off in the hole. Unfortunately, I couldn't get the two step screw extractor in the size I needed.
KevKaos
RED JEEP CLUB # 621
KevKaos is offline
post #41 of 43 Old 05-11-2011, 07:14 AM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
I've seen a number people use the wrong size torx bit as well. The right size some times doesn't fit in there as the paint is in the way. Another good fix is to use reverse drill bits.
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #42 of 43 Old 05-11-2011, 12:22 PM
Deuskid
Originally Posted by Chris @ GATR View Post
Impatience is the only thing that strips a Torx on a Jeep. Slow down, use PBB on EVERY ONE, let it soak a bit, put enough clockwise torque on it to unseaat the Torx, then loosen. Works like a charm every time and I have had countless Torx on/off my Jeep.
What is PBB?
Thanks,
john
Deuskid is offline
post #43 of 43 Old 05-11-2011, 01:07 PM
p997c4s
PBB is PB-Blaster, makes your garage smell good
p997c4s is offline
Windshield Hinge Torx Bolts PSYCH0 JK Wrangler Technical Forum 8 01-30-2010 08:15 AM
More stripped torx bolts? Deadhorse TJ Wrangler Technical Forum 3 05-21-2009 06:50 AM
solution for stripped torx bolts YJ_95 YJ Wrangler Technical Forum 15 05-26-2008 11:16 AM
specific torx bit for stripped tailgate hinge bolts? first5.0 TJ Wrangler Technical Forum 9 03-31-2007 12:59 PM
Removing stripped Torx bolts voigtrobert TJ Wrangler Technical Forum 2 02-17-2006 11:57 PM
