HELP! Stripped torx bolts on window hinge - Page 2 - JeepForum.com
post #16 of 43 Old 08-24-2007, 08:09 PM
claytonandson
claytonandson's Avatar
torx metric vs SAE(american)
not that it matters for you at this point,but when i got my TJ new in 2003, first thing i did, weekend at a time ,was replace most of my screws and bolts w/ stainless steel sae hex heads and put never seize on each one as i did it. it has made life sooooo easy as i've done mods over the years. forgot to metiom,i also had to re-tap everything SAE also.possibly some good advice for others.
yellow jeep club #343
IAFF /FF's OF WASH. D.C. EMERALD SOCIETY/CHARLES COUNTY RESCUE SQUAD 51
claytonandson is offline
post #17 of 43 Old 08-24-2007, 08:10 PM
charlescho
charlescho's Avatar
Originally Posted by distantdog
How much did you have to pay the shop to do it? I went to one today and the guy said something like $75!
This is so f*cked! I have two left to get out, the one on the front side of the hinges on each side.
I have successfully broken off two bits, one in each, so now i have a hard piece of steel stuck in my drilled out bolts, neither of which wants to move.
I bought the grabit thing mentioned above. Didnt work. I drilled it in and my power drill torqued out. So i took off the drill and tried turning the grabit bit with a socket wrench. IT BROKE OFF THE HEAD OF THE GRABIT BIT.
Talk about frustration. I am at a loss at what to do. These bolts show no sign of wanting to turn at all.
Further more, one of the bolts that was stuck, I drilled into and it broke off the head, but it also broke off whatever the two torx bolts screw into on the inside of the hinge. Whatever that is is just rattling around in there now.
WTF JEEP!
brigng it here and its free
well given you supply the nuts
ABC - A/Ox4 - SAMPLE - OPQRST
charlescho is offline
post #18 of 43 Old 08-24-2007, 09:05 PM
marc1kim
Using heat ( torch) works good, but'll probably screw up your paint. But you'll be covering that with your cage mount anyway.
05 LJ
08 JKU Rubicon
marc1kim is offline
post #19 of 43 Old 08-24-2007, 09:13 PM
BozoWise
BozoWise's Avatar
Another way to avoid the stripped torx is to use a hammer impact. It is a devise that the torx bits goes on, or a socket and you hit it with a hammer. It has a twisted shaft and transfers the downward force into twisting toque so the torx bit stays aligned and is forced down as it turns.
My 1 ton TJ build project "Evil Monkey":
BozoWise is offline
post #20 of 43 Old 08-24-2007, 09:18 PM
Jeff65SS
Do you have a link to one of these tools? It sounds very interesting.
Jeff65SS is offline
post #21 of 43 Old 08-24-2007, 09:30 PM
samuelshoun
http://www.harborfreight.com/cpi/cta...emnumber=37530
there are better ones.
i suggest holding these with a set of channel locks or vise grips if you're really pounding on em.
99 TJ, 3" sus lift, 33x12.50 mickey baja MTZ's, MM SE9500C winch .... more in the works ;D
samuelshoun is offline
post #22 of 43 Old 08-24-2007, 09:38 PM
claytonandson
x2 on the impact hammer tool.trick is you gotta get it on the first whack to avoid stripping.
post #23 of 43 Old 08-25-2007, 07:55 AM
Jeff65SS
Thanks! I'm gonna get one. Now to find a "quality" one.
Jeff65SS is offline
post #24 of 43 Old 08-25-2007, 08:03 AM
will228
will228's Avatar
im sorry i think your going to have to get a new jeep...
will228 is offline
post #25 of 43 Old 08-25-2007, 08:27 AM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
I thought it was just me! Had a couple hours to burn and thought "Hey, I'll put the new mirrors on the windshield frames so I can take off the doors during the summer!
Well, one of the torx bolts took an hour to get off! The nut inside the windshiled post broke free after getting half way out! I had grind the head off and pop it thru.
What a major pain in the butt! I never could get the others out. It frustrated me so bad I had to buy another Jeep!
Savvy is offline
post #26 of 43 Old 08-25-2007, 09:46 AM
will228
will228's Avatar
haha sometimes thats just what it has to come down to.
will228 is offline
post #27 of 43 Old 08-26-2007, 03:37 PM Thread Starter
distantdog
Well I am breaking down and taking it to the shop. What a bunch of crap. I have mangled the bolts so bad that there is not much to work with anymore. This has to be one of the most frustrating things I have ever come across in all my years of amature automotive work...
distantdog is offline
post #28 of 43 Old 05-07-2008, 12:24 PM
Deere9670
Will welding around my paint mess it up?
Originally Posted by Fred99TJ View Post
Weld a nut onto the head works everytime.
I drilled mine out and tapped them larger and simply replaced them with the larger hex bolts
Im in the same situation. I want to put my mirror movers on and take the doors off. but the stupid torx bolts are stuck in there and almost stripped! Will welding a nut on there mess up the paint around it? Is welding the way to go?
Deere9670 is offline
post #29 of 43 Old 05-07-2008, 01:08 PM
Chris_
Drill some of the bolt out using a drill bit to weaken the bolt (probably a 3/16 on that size), then use a dremel to cut a slot in the head of it, and you can use a flat head to back it out. I've done this a bunch. In fact, I did this just the other day on two of the tail gate bolts.
'02 TJ X Apex Edition
'00 XJ Sport
Chris_ is offline
post #30 of 43 Old 05-08-2008, 10:41 AM
Deere9670
I dont have any experience with that method, nor do I own a dremal. I would like to try the welding the nut on method, but am worried about messing up the paint on the jeep. I know that during the summer with the mirror mover brackets in place it, will cover up any marks left on from welding aroud the area, but I am concerend about wither when the mirrors are back in there original place. Does anyone know if the weld will damage the paint around the bolts?
Windshield Hinge Torx Bolts PSYCH0 JK Wrangler Technical Forum 8 01-30-2010 08:15 AM
More stripped torx bolts? Deadhorse TJ Wrangler Technical Forum 3 05-21-2009 06:50 AM
solution for stripped torx bolts YJ_95 YJ Wrangler Technical Forum 15 05-26-2008 11:16 AM
specific torx bit for stripped tailgate hinge bolts? first5.0 TJ Wrangler Technical Forum 9 03-31-2007 12:59 PM
Removing stripped Torx bolts voigtrobert TJ Wrangler Technical Forum 2 02-17-2006 11:57 PM
