HELP! Stripped torx bolts on window hinge - JeepForum.com
post #1 of 43 Old 08-21-2007, 06:01 PM Thread Starter
distantdog
I am trying to install my new Kargomaster congo cage...
You have to mount the front part to the upper window hinge which requires you to remove the torx bolts.
I got a few of them to snap loose, but about half have stripped completely! Its amazing, even without much pressure they were like frickin butter. Crap.
Anyway, now I have drilled into one in order to use a screw extractor, which has not worked so far. I have only successfully drilled a hole in the screw and then stripped it out with the extractor bit.
Anyone else ever have trouble with these bolts, and if so, how did you get them out?!
distantdog is offline
post #2 of 43 Old 08-21-2007, 06:57 PM
Mike
oooh you almost had it
Mike's Avatar
I have, and I used Craftsmans screw extractor. I ended up drilling them out carefully and using their product. Your pain is felt.
Mike is offline
post #3 of 43 Old 08-21-2007, 07:02 PM
Flawed
I did the same thing. All I did was drill the bolts out with a 1/4 in drill bit a little deeper than the torx bit was. Then I took a hammer and pounded in one of those 1/4in alan type screw driver attachments in to the hole. Put a 1/4in socket on it and twisted it out. This has worked for me 3-4 times on mine and my buddies rigs. Every time I have ever tried to remove one of those torx bolts they have striped.
Flawed is offline
post #4 of 43 Old 08-21-2007, 07:29 PM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
When my diff bolts supplied by Warn got stripped I tried a bolt extractor unsucessfully. So, I bought a small circle shaped drill bits from Harbor Freight and cut a vertical line in the middle of the head. Then I used large chisel or flat head to hammer turn the bolt loose. Good luck.
2009 JK Rubicon (Former Daily Driver); 2014 VW Jetta GLI Autobahn w NAV.
Auto, Power, Remote Start, Towing Package, MyGig Navigation with Lockpick, Rear View Camera, B&M 70268 Transmission Cooler, Aeroforce Interceptor, Valentine 1, Tub Sound-Deadened with Raamat and Ensolite, Hard Top Heat Insulated with 1/2" Styrofoam Insulation, Bilstein Shocks Front & Rear, PIAA Dual Horns, IPF 920H4 Headlights.
Protection: Skid Row Engine Skid, Lower Control Arm skid & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Differential Skid Front & Rear.
Recovery Gear: Warn 9.5Ti Winch, 11,000# Pull-Pal.
Communication: Uniden 520XL CB, Diesel External Speaker, 3' FireStik Whip.
Shrockworks Mid-width Front Bumper with Warn 9.5Ti Winch -- Ordered 7/17/2009; Bumper Received 12/4/2009.
1" Coil Spacer Front & 1/2" Coil Spacer Rear restored OEM Rake.
4x4 Trips:
Moab - 4/2006, 5/2008, 4/2009, 5/2011, 4/2013
Ouray - 8/2007
Rubicon - 9/2008
Gone, but not forgotten: 2004 TJ, 1999 Audi A4, 1992 VW Jetta GL 5 Speed
Thunderstrike is offline
post #5 of 43 Old 08-21-2007, 07:32 PM Thread Starter
distantdog
Well I feel a little better now... at least I got a few of them out. I'm gonna try the 1/4 inch allen thing method...
I will let you know how it turns out.
I think it would be a laugh to hear all the F'd up ways that people have dealt with this problem.
post #6 of 43 Old 08-21-2007, 08:10 PM
Fred99TJ
Weld a nut onto the head works everytime.
I drilled mine out and tapped them larger and simply replaced them with the larger hex bolts
Fred99TJ is offline
post #7 of 43 Old 08-21-2007, 10:33 PM
BozoWise
BozoWise's Avatar
I also used the circular disk cut and flathead method with success.
My 1 ton TJ build project "Evil Monkey":
BozoWise is offline
post #8 of 43 Old 08-22-2007, 07:41 AM
tjwoo
tjwoo's Avatar
stripped 3/4 of mine as well. I let out many expletives, then spit on it and left. Eventually I came back, pb blastered it, drilled it and extracted using ez out.
torx = hatehatehatehatehate
tjwoo is offline
post #9 of 43 Old 08-22-2007, 07:59 AM
bigj1974
bigj1974's Avatar
http://4grabit.com/Default.asp?bhcp=1
I ordered this thing. seems pretty practical.
I'll let you all know if it works as advertised.
bigj1974 is offline
post #10 of 43 Old 08-22-2007, 08:44 AM
luk4mud
I have had to resort to the "weld a nut on method" as well. The only problem is I can't weld, so I had to take it to a shop to get it done. Before I did, I tried everything else noted above and none of them worked.
Originally Posted by Divinitous
I did something like this a while back for my corolla. I poked a hole into the ducting and ran a hose to stick into my shorts. It didnt work thew best cause I never plugged up the vents, but it did help.
luk4mud is offline
post #11 of 43 Old 08-24-2007, 06:25 PM Thread Starter
distantdog
How much did you have to pay the shop to do it? I went to one today and the guy said something like $75!
This is so f*cked! I have two left to get out, the one on the front side of the hinges on each side.
I have successfully broken off two bits, one in each, so now i have a hard piece of steel stuck in my drilled out bolts, neither of which wants to move.
I bought the grabit thing mentioned above. Didnt work. I drilled it in and my power drill torqued out. So i took off the drill and tried turning the grabit bit with a socket wrench. IT BROKE OFF THE HEAD OF THE GRABIT BIT.
Talk about frustration. I am at a loss at what to do. These bolts show no sign of wanting to turn at all.
Further more, one of the bolts that was stuck, I drilled into and it broke off the head, but it also broke off whatever the two torx bolts screw into on the inside of the hinge. Whatever that is is just rattling around in there now.
WTF JEEP!
post #12 of 43 Old 08-24-2007, 06:41 PM
mudcreeker
I have took a torx bit and put it in the screw then hammered on the bit a little bit , tried to tighten first then loosened up alittle ,make sure that the screw hole where the bit goes in is cleaned out good , if it ever moves a little bit just keep working it back and forth, (tighten and loosen) I haven't stripped one out yet, I have been replacing all of mine with ss allen head and a little bit of swak on the threads , GOOD LUCK and have a lot of patience with these
mudcreeker is offline
post #13 of 43 Old 08-24-2007, 06:49 PM
MillerTimeTJ
yeah i notched mine with a small wheel on my dremel
a
97 TJ Sport, 5 Speed. 2.5 RC Spring Lift, 1.5 BL. 33" Trxus MT.
MillerTimeTJ is offline
post #14 of 43 Old 08-24-2007, 06:54 PM Thread Starter
distantdog
I guess I will try that method. This is ridiculous.
post #15 of 43 Old 08-24-2007, 07:51 PM
Chris @ GATR
Chris @ GATR's Avatar
Impatience is the only thing that strips a Torx on a Jeep. Slow down, use PBB on EVERY ONE, let it soak a bit, put enough clockwise torque on it to unseaat the Torx, then loosen. Works like a charm every time and I have had countless Torx on/off my Jeep.
Got ignorance? Please see below.
Originally Posted by kd4yor View Post
Chris, I just think your having buyers remorse for all the work in your 8.8 for no added gain (over the Dana 35).
Chris @ GATR is offline
Windshield Hinge Torx Bolts PSYCH0 JK Wrangler Technical Forum 8 01-30-2010 08:15 AM
More stripped torx bolts? Deadhorse TJ Wrangler Technical Forum 3 05-21-2009 06:50 AM
solution for stripped torx bolts YJ_95 YJ Wrangler Technical Forum 15 05-26-2008 11:16 AM
specific torx bit for stripped tailgate hinge bolts? first5.0 TJ Wrangler Technical Forum 9 03-31-2007 12:59 PM
Removing stripped Torx bolts voigtrobert TJ Wrangler Technical Forum 2 02-17-2006 11:57 PM
