Help with Steering Wheel "Shimmy" at 35mph - JeepForum.com
post #1 of 3 Old 06-08-2006, 08:35 PM Thread Starter
warner41
I just bolted on my new wheels and tires after a bunch of mods over the last few days. For some reason my steering wheel has a shimmy between 32 mph and 38 mph whether I'm speeding up or slowing down. As soon as I hit either end of that range it will shimmy and then quickly stop when I am out of that range. Has anyone had a similar experience? I will list all of the work I've done over the last 5 days culminating with the install of the wheels and tires today which is when it showed up. I am adding a skyjacker steering stabilizer and rear extended sway bar links tomorrow, I don't know it the stabilizer will have any effect.
2006 X, 6 speed
Rancho 2.5" coils
Skyjacker Hydro 7000's
OME Track bar relocation bracket
OME Bump stop extensions
JKS 1.25" BL & BMML
BFG 33x12.50 Mud Terrains on M/T Classis II's
Thanks
warner41 is offline
post #2 of 3 Old 06-08-2006, 10:55 PM
Scott_98TJ
Without knowing what else you worked on, I'd have to go with a bad balance on the new tires before anything else. Rotate the tires and see if the symptoms change.
98 TJ 4.0L | GenRight Stretch, 4 Link | Built XJ HP30 & XJ 44 | AW4 | ARB's | 35" Krawlers | Allied Beadlocks | York OBA | Warn 9500i etc. | M416 Trailer
Scott_98TJ is offline
post #3 of 3 Old 06-08-2006, 11:18 PM
jmreagan
jmreagan's Avatar
Warner41,
I had the same problem after a 3 inch suspension intstall and lived with it for a week. I only had very minor vibes in roughly the same mph range. Well, tonight I decided to install the TC drop and bam, the slight shimmy in the wheel went away. I also had death wobble for the past week and took the spare off the back and put it on the front passenger side, tightened my trac bar and had an alignment. No more DW that GOD!
1). Get an alignment if you didn't
2). Make sure your wheels are 0 - 0 balanced
3). Tighten your track bar to spec and make sure the bushings on it are not worn.
I see you do have a MML. Are you experiencing vibes or just a shimmy?
03' Sport, 4.0L, 3.73, 5 speed, D44/D30, 3 inch coil/shock lift, RE track bar, Tera disco's, 35x12.50's Dunlap Mud Rovers MT's, Spidertrax spacers, Viper 5000 alarm, Tuffy console, LOD extreme bumper/tire carrier and front bumper, A-Z rockers, AA SYE, Tom Woods DS, JKS Rear UCA's.
Originally Posted by KKiowaTJ
Sorry master, Dont whips me, I's do betta next time..
jmreagan is offline
Steering Wheel Shimmy at 45 mph after 2" Budget Boost. Suggestions? hddeuce TJ Wrangler Technical Forum 2 11-14-2009 09:39 PM
Steering seems loose and wobbles in bumpy turns after 4" Lift and 33" M/T Tires/Wheel cpd3020 TJ Wrangler Technical Forum 8 10-28-2009 01:18 AM
Is the steering wheel "clunk" a safety concern? sdebol JK Wrangler Technical Forum 8 06-23-2009 06:05 PM
"Pulsing" Steering Wheel During Slow Turns Hamish TJ Wrangler Technical Forum 6 06-28-2008 09:01 AM
Not your usual "steering wheel isn't centered" question rbaker TJ Wrangler Technical Forum 8 03-31-2006 04:09 PM
