Help with steering shimmy - JeepForum.com
post #1 of 1 Old 10-04-2006, 04:59 PM Thread Starter
WenieD
All of the sudden when turn corners at low speed or high speed the steering wheel "and jeep" shakes back and fourth.
I took the jeep in to the local shop and the rotated and balanced my tires and checked my alignment. The tires were in fact out of balance and the toe-in was very slightly set too wide.
They also checked the tightness off the track bar bolt and control arm bolts and everything else.
The wobble at 45 mph while going straight is now gone but it still shimmys when turning. What confuses me is that this problem started all at once. I went to lunch and when coming back from lunch it started doing this.
What else could it be?
WenieD is offline
steering wheel shimmy rsant39 TJ Wrangler Technical Forum 6 08-11-2012 05:29 PM
yet another steering shimmy. what to do now? bow_hunter8 TJ Wrangler Technical Forum 7 02-09-2010 05:32 PM
Steering Shimmy and Wandering Billyjon1 TJ Wrangler Technical Forum 17 12-22-2009 07:19 AM
steering column shimmy cragrat TJ Wrangler Technical Forum 0 11-20-2007 08:15 PM
Steering shimmy Jeepin' Rock Cl TJ Wrangler Technical Forum 8 03-31-2005 05:08 PM
