help. Snapped transmission mount to skid plate bolt! - JeepForum.com
post #1 of 16 Old 04-23-2006, 01:29 PM Thread Starter
ClemsonJeepGC
I was only at about 35 foot pounds when it snapped! How do I fix it? Is the jeep driveable with just 3 tight bolts instead of the four?
I was trying to fix another problem and now I have 2 problems. The original problem was that there is a random clicking noise that isnt consistent and it sounds like it is coming from above the tcase skid plate somewhere. I was thinking maybe those 4 bolts needed loosened and then retightened cuz maybe something was binding. So, I loosened them and went up the driveway and back and then tightened them back. Got out the torque wrench and was going for 45 foot pounds and it snapped at 35 or so.
1998 Green Sahara - Rusty's 3", 33x12.50 BFG AT, RE Track Bar, Gambler wheels, 1.25" spacers, home made window roll, rear olympic rockslider bumper, Kenwood KSC-SW1 Sub
2004 Black Tacoma TRD
ClemsonJeepGC is offline
post #2 of 16 Old 04-23-2006, 03:37 PM
azcoyote
azcoyote's Avatar
You need to use a bolt extractor to remove it. Essentially, you drill a small hole down the middle of the snapped bolt and then use a special extractor bit to screw the bolt out. Make sure to use PB Blaster or something like that to help with the bolt. Here is a link to an example.
http://www.mytoolstore.com/hanson/extractr.html
Ask at the <insert your favorite store> (Pep Boys lends) about what they have to lend but you may have to buy one...
Cheers,
JEEPLESS... :(
azcoyote is offline
post #3 of 16 Old 04-23-2006, 04:13 PM
NetJunkie
Sears sells bolt extractors. Like the above said, drill a small hole in the center of the bolt then use an extractor.
'04 Rubicon | Nth Degree 4.5" LA | ORO SwayLoc | ORO U-Turn Steering | 33x12.5x15 MTRs | 15x8 Streetlock Rims | AEV Rockers | ARB Winch Bumper | Warn XD9000i | Offroad-Technology Rear Bumper
NetJunkie is offline
post #4 of 16 Old 04-23-2006, 04:51 PM Thread Starter
ClemsonJeepGC
Im not sure that will work. The end of the bolt snapped off with the nut. I dont know how to get to the head of the bolt and dont know if there is a head? Is the bolt one piece and I have to replace the whole mount?
Im not talking about the bolts that hold the skid plate on, but the nuts to the bolts that mount the transmission to the skid plate (the ones you have to loosen before you lower the tcase)
post #5 of 16 Old 04-23-2006, 04:55 PM
azcoyote
azcoyote's Avatar
Well, I was going to say that the process should work regardless... As long as you have a steady hand and take your time during the drilling process. You don't want to harm any threads on the drilling...
However, you have me a little confused now. Can you post up a pic? Extractors are for when you shear off the head and the threads are left in the hole. Is that not how yours is?
If the remaining bolt section is non-threaded, you can use a punch and hammer to tap it out (assuming you can see both sides of the hole). If it is threaded, the afore mentioned method is what you will have to do.
JEEPLESS... :(
azcoyote is offline
post #6 of 16 Old 04-23-2006, 05:14 PM Thread Starter
ClemsonJeepGC
the bottom of the bolt snapped off when i was tightening the nut. The head (if it has a head) is still in the mount. I will have to take pictures. Ill have them in 30 min.
post #7 of 16 Old 04-23-2006, 05:20 PM
azcoyote
azcoyote's Avatar
Just so we are all on the same page...
JEEPLESS... :(
azcoyote is offline
post #8 of 16 Old 04-23-2006, 05:32 PM
kingvm
kingvm's Avatar
2005 WK
Those are studs molded into the transmission mount.
You should be ok with 3 for a while, many jeeps run with the complete mount broken for a long time before finding it.
You will probably have to replace the tranmission mount.
Try rockauto.com for a good price on one.
05 Grand Cherokee Limited, 5.7 hemi, quadradrive II, Nav, 3" lift, JK Rubi wheels/tires, 4xGuard skids
kingvm is offline
post #9 of 16 Old 04-23-2006, 05:33 PM
azcoyote
azcoyote's Avatar
OK. Reread your post and I think I am following you now... Your were removing a nut when the stud that the nut was on broke. Is that correct?
JEEPLESS... :(
azcoyote is offline
post #10 of 16 Old 04-23-2006, 05:34 PM
azcoyote
azcoyote's Avatar
Kingvm - Do you know if those press our or are the screw in?
JEEPLESS... :(
azcoyote is offline
post #11 of 16 Old 04-23-2006, 05:37 PM Thread Starter
ClemsonJeepGC
http://community.webshots.com/album/548086273USCrDv
pics
post #12 of 16 Old 04-23-2006, 05:39 PM Thread Starter
ClemsonJeepGC
Yea, the stud end, not the head of the bolt. I tried to push it out with a screw driver and it didnt budge. I tried to stick my head up there to see where it goes and I couldnt see. All I could see is what you can now see in the pics.
post #13 of 16 Old 04-23-2006, 05:45 PM Thread Starter
ClemsonJeepGC
h i just saw KingVMs post about the mount....thanks for the help guys. I guess I know what I have to do now. Do yall think that is what was causing my clicking problem? I guess I just have to take the jeep for a spin to find out.
post #14 of 16 Old 04-23-2006, 05:49 PM Thread Starter
ClemsonJeepGC
25 bucks. I guess it could have been worse. How hard will that be to swap out kingvm? Is there a write up?
post #15 of 16 Old 04-23-2006, 06:09 PM
kingvm
kingvm's Avatar
2005 WK
It took me about 1/2 hour to change mine. I don't know about a writeup, but here are the basic steps.
Remove the other 3 nuts.
Place a jack under the tailshaft or housing of the trans just behind the skid plate to hold it up.
Remove the skid plate and drop it down. (It helps to have a floor jack under it to lower but it can be done by hand.)
Once the skid plate is out of the way you can see how to remove the old mount. (I think there are 4 bolts holding it to the transmission.)
After the new mount is bolted to the transmission, replace the skid plate making sure the studs come thru the holes in the skid.
They say to drive it forward and back a few feet to let the studs find the proper place in the slots before tightening them.
kingvm is offline
Snapped grade 5 skid plate bolt off vtx531 TJ Wrangler Technical Forum 42 10-07-2009 05:20 PM
Transmission to skid plate mount champelite210 YJ Wrangler Technical Forum 1 09-21-2008 04:10 PM
Snapped a transmission mount bolt on T-Case skid plate blueteej TJ Wrangler Technical Forum 2 04-06-2007 05:19 AM
Snapped Body Mount Bolt Ichabod1960 TJ Wrangler Technical Forum 3 10-09-2006 08:02 PM
weird bolt/mount on skid plate/tranny ?? evilpsych YJ Wrangler Technical Forum 5 11-11-2001 02:28 AM
