Quantcast HELP. serp. belt - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > HELP. serp. belt
Black Magic Brakes - 5% Off, No Minimum Purchase RequiredOfficial Chassis Saver Rust Preventive Truck & Auto UnIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 05-29-2005, 03:35 PM   #1
drew76924
HELP. serp. belt
i'm trying to put a new serp belt on and i can get the shrouding the goes around the fan off is there anyother way toreplace the belt
drew76924 is offline   Reply With Quote
Old 05-29-2005, 03:51 PM   #2
BigWaylon
tubework is cool...
BigWaylon's Avatar
you don't need to remove that...what year TJ? and the 4-cylinder or 6-cylinder?
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
www.carolinarockshop.com
All the pics I have...including a Table of Contents
BigWaylon is offline   Reply With Quote
Old 05-29-2005, 04:13 PM   #3
Stu Olson
Stu Olson's Avatar
Greg
Agreed
Stu Olson
ARB Locked & Loaded
www.stu-offroad.com
Stu Olson is offline   Reply With Quote
Old 05-29-2005, 04:19 PM   #4
BigWaylon
tubework is cool...
BigWaylon's Avatar
OK...I searched your old posts, and found that you have a '97...but I'm not sure of which engine...
here's the routing diagram for a '97...and it shouldn't matter which engine:
there should be a bracket on the Power Steering bracket...with a bolt through the top...that's the bolt you'll need to loosen to get enough slack to remove the old belt...
let me know if you need more detailed instructions...actually, I just checked Stu's site, and he has the write-up already (surprise, surprise)...check about half-way down this page:
http://www.stu-offroad.com/engine/radiator/radiator-4.htm
Greg
Glock Forum
