Quantcast Help Removing TC Shifter Grip - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Help Removing TC Shifter Grip
Spartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase RequiredDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 01-28-2008, 02:16 PM   #1
Pillswoj
Hopefully someone has done this and can help, I have done a leather shift boot and carved an Oak shift knob, pictures below. I would like to carve and oak handle for the transfer case shifter as well.
http://farm3.static.flickr.com/2030/2226885016_994e98da93_o.jpg
http://farm3.static.flickr.com/2356/2226094121_28242a749e_o.jpg
How do I get the rubber grip off? Does it have to be cut off and if so how long is the metal shaft once done?
If anyone has remove the grip from the transfercase shifter a picture of it with nothing on it would be a great help.
Thanks,
Jeff
Pillswoj is online now   Reply With Quote
Old 01-28-2008, 02:33 PM   #2
klimb2xs
Looks good. I never pulled the grip from mine. Are you interested in reusing the T-case grip? If not just cut it off and be done with it.
Thanks,
Jeff
Black Jeep Society
Originally Posted by walldk View Post
Step away from from the vehicle and seek professional help.
klimb2xs is online now   Reply With Quote
Old 01-28-2008, 02:41 PM   #3
Pillswoj
Thanks for the click free.
Not planning on reusing the grip, but I wanted some Idea of what I have to work with under it before I started cutting.
Jeff
Old 01-28-2008, 03:33 PM   #4
Zoom By You
Knob and boot looks good, looks like it belongs in a Jaguar....
2001 TJ Sport Amber Fire, Dual Tops/Dual Doors, 4.0, Banks Ram-Air, Banks S.S. Monster exhaust, five speed, NV3550, A.A. SYE/Tom Woods, 4:56 D30/D35, Detroit Truetrac at both ends, Solid diff covers, 4.5 R.E. Super Flex W/3.5 springs, adjustable upper and lower control arms, adjustable front and rear R.E. track bars, TeraFlex shock relocation brackets, R.E. Mono tube shocks, R.E. front stabilizer, R.E. 3/4" front spacer, 33 X 12.5 TrXus STS, M/T Classic-locks, ShrockWorks Rock Rails, Hanson 52" front bumper, EPi9.0 Superwinch with wireless control, Olympic rear bumper, Olympic Mountaineer rack, Bushwacker 6" Pocket Flares, Optima yellow top, IPF headlights W/ Fatboys, upgraded relay/wiring harness, KC Slims, Bosch rear lights, Garmin c550 GPS, Garmin 76S GPS, Cobra CB 148GTL W/Astatic Mic, Pioneer Sound, 3A Racing fire extinguishers. Manhattan Rated....
Zoom By You is offline   Reply With Quote
Old 01-28-2008, 03:41 PM   #5
Bigbob
Bigbob's Avatar
How do I get the rubber grip off? Does it have to be cut off and if so how long is the metal shaft once done? Thanks, Jeff
I bet the grip is glued on. Either the steel goes close to the end or there is a plastic sleeve in there as that grip is pretty solid on mine. I guess you will need to cut it off. You could call the dealer and see if the have a replacement grip. I bet the grip and shift lever are all one piece.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline   Reply With Quote
Old 01-28-2008, 04:01 PM   #6
Dogman
PM Bluesman or Chili Palmer. I know they both put different handles on theirs. They should be able to answer your question.
Dogman is offline   Reply With Quote
Old 01-28-2008, 04:14 PM   #7
jeeptillidie
Get a thin cutting wheel on an air grinder and go to town.
jeeptillidie is offline   Reply With Quote
Old 01-28-2008, 06:07 PM   #8
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Funny, I immediately thought Jaguar too even before seeing you said the same thing. Mighty fancy if you ask me.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 01-28-2008, 08:21 PM   #9
Pillswoj
Thank you for the compliments, didn't think Jag when I did it it just sort of happened as I went along....
When I bought the jeep, the rubber boot was pulled up and the bezel was missing, in researching here I discovered it was most likely done to help with the shifting into 2nd in the cold. Decided to make a leather boot and got a good deal on brown leather which I liked better with the tan interior anyways.
Still wasn't pleased with the feel of the stock shifter so I put a B&M short shifter in, it was much more precise but with the stock jeep knob it was to short. All the aftermarket knobs locally were too "ricer" but I had an extra piece of oak from doing my stair railing so I decided to try carving one - 4 hours later with chisels, dremel etc. thats what I came up with.
Now I want the Transfer shifter to match. Guess I need driving gloves and hat if its now the Jag Jeep
Jeff
Old 01-28-2008, 11:08 PM   #10
subaruboy
Jeff
my shifting was miserable in the cold buy i switched the tranny oil to synthetic and it's a charm now just something to think about if you haven't done it already
2000 Jeep TJ SE Amberfire Pearl- Sold, I miss her
1995 Escort LX
2005 PBM M6 GTO
subaruboy is offline   Reply With Quote
Old 01-28-2008, 11:43 PM   #11
RnEmOvr
Never Forget
RnEmOvr's Avatar
you must cut the old one off and thread it using a die
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
Guns have only two enemies; rust and politicians.
www.cityprofile.com
RnEmOvr is offline   Reply With Quote
Old 01-29-2008, 12:24 PM   #12
Pillswoj
Pictures with Grip cut off
Thought I'd update with pictures, cut the grip off with 1 slice along the top with a utility knife (pried out the shift pattern insert first.
Pictures of the bare shaft:
Side view:
http://farm3.static.flickr.com/2414/2228313517_53cb065d8f.jpg
Top View:
http://farm3.static.flickr.com/2339/2228313549_7b9daa4aa9.jpg
Old 01-29-2008, 01:03 PM   #13
klimb2xs
Side view:
Top View:
Click free...
How do you plan on attaching the new handle? I think you could thread the lever.
Black Jeep Society
Old 01-29-2008, 01:21 PM   #14
Pillswoj
Thanks for the click free,
I am unsure as of yet how I am going to attache the new handle, I haven't even started to carve it yet . If it had been round stock all the way out I was going to thread it and just screw the handle on. with the long flat section (which I don't want to cut off) I may still thead it or I may drill 2 holes in it and put screws through from the side. Still sorting that out.
Old 01-29-2008, 01:52 PM   #15
TJ Flexer
I cant wait to see what you come up with. JAG JEEP that funny, I don't care who you are, thats funny right there.
TJ Flexer is offline   Reply With Quote
Glock Forum
