Quantcast HELP - Removing Stock Steering Stabilizer - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > HELP - Removing Stock Steering Stabilizer
Truck-Lite's New LED Headlamp SeriesRuffstuff Axle Simple Swap Kit!Spartan Lockers FREE SHIPPING Excellent Prices
Old 07-02-2006, 06:46 PM   #1
roadking
roadking's Avatar
Having trouble removing the stock steering stabilizer from the tie rod...not the end by the tire, but the one half way up the rod. The new one looks conic, like a press-fit, that gets tighter as you tighten it. Is the stock the same, and do I need to bang the hell out of or does it unscrew?
Thanks!
Gotten Savvy! Awaiting Tummy Tuck ;-)
http://video.google.com:80/videoplay?docid=-2512249746173560379&pr=goog-sl
65 million firearms owners killed no one yesterday - Assault is a behavior, not a device.
roadking is online now   Reply With Quote
Old 07-02-2006, 06:54 PM   #2
orangetj05
bang the crap out of it with a huge hammer it should fall out.
2005 TJ Caged, Locked, Long armed, Stretched, Air shocked, Cromoed, Running 37 Irocks
ORANGE JEEP MEMBER #8
orangetj05 is offline   Reply With Quote
Old 07-02-2006, 07:16 PM   #3
LJ Dave
Be careful not to bend the drag link if you are banging it with a BFH.
Dave S.
LJ Dave is offline   Reply With Quote
Old 07-02-2006, 07:23 PM   #4
BigWaylon
tubework is cool...
BigWaylon's Avatar
hit the drag link where the bolt goes through...usually a good couple whacks and it'll pop out...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
www.carolinarockshop.com
All the pics I have...including a Table of Contents
BigWaylon is offline   Reply With Quote
Old 07-02-2006, 10:00 PM   #5
markc522
i agree with everyone so far.
yelling helps.
2003 wrangler x
somewhere around a 4" frakenlift -
33" claws - black soft 8's - dt8000's - disco's
yellow jeep club member #874
JEEP: 1 2 3 4 5 6 7 8 9 10
markc522 is offline   Reply With Quote
Old 07-02-2006, 10:02 PM   #6
MCanavan
You could rent a pitman arm puller from autozone, that's what I did when I replaced my SS. BFH helps too though.
MCanavan is offline   Reply With Quote
Old 07-03-2006, 12:24 AM   #7
Photojeep
I had my mechanic change mine out and he didn't want to use a hammer on my "new" jeep (only had it about a month.)
He used a puller thing, sorry don't know the real name, on which he used an air wrench to make it "snap" free. I had two arms that came around and grabbed the stationary piece and a heavy duty bolt that pushed on the tapered piece to force it out.
I'm glad I didn't try to do it myself. If I had , I would still be working on it and I had it done in January!
Good luck,
Randy
Photojeep is offline   Reply With Quote
Old 07-03-2006, 01:38 AM   #8
JxxxOxxxE
Thanks!
Well, I just changed mine out today....After seeing my brother screw around with his a few weeks ago, I hit mine twice with a BFH today, then just decided to get the torch out and heat the area around it a little bit....Sure enough, first hit after being heated it popped right out....
JxxxOxxxE is offline   Reply With Quote
Old 07-03-2006, 08:16 AM   #9
Srjeeper
Use a Pitman Arm Puller. It saves time, effort, and steering parts. LOL
[FONT="Comic Sans MS"][B]JEEPAHOLIC[/B][/FONT]
Srjeeper is offline   Reply With Quote
Old 07-04-2006, 12:56 AM   #10
roadking
roadking's Avatar
I put some lube on it and let it sit overnight...thyen smacked it with a BFH...popped right out. New one installed in just a few minutes.
Thanks guys
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
