Help. Rebuilt 4.0 and timing is off - JeepForum.com
post #1 of 29 Old 05-23-2012, 08:46 PM Thread Starter
funnyduck84
I just did a rebuild on my 4.0 and now it runs rough if it wants to start. I put a mild howards cam and bored it 30 over. Is there any thing I can do to fix it or am I screwed
funnyduck84 is offline
post #2 of 29 Old 05-23-2012, 09:01 PM
Dice48
Thats kinda a vague description but if I had to guess I would say start with checking the timing.
KCCO
Dice48 is offline
post #3 of 29 Old 05-23-2012, 09:02 PM
Dice48
ANd before everyone else jumps on ya about it you should really fill out the info on your jeep in your profile so we can see what you got to better help you with problems.
KCCO
Dice48 is offline
post #4 of 29 Old 05-24-2012, 09:46 AM Thread Starter
funnyduck84
The timings off. It's at 30 degrees. But I can't turn the distributer enough to fix it.
post #5 of 29 Old 05-24-2012, 11:44 AM
silver97tj
silver97tj's Avatar
hi all
check to see if distributor was indexed right, rotor points to TDC at piston one, or pull timming cover and make sure the chian is not streched or that the timing marks are aligned properly. it seems the timing is ways off.................good luck.
1998 Blue TJ, 4 Cyl., Auto (30rh), Hardtop with installed Sunroof, mostly stock.
31x10.5x15 Mud Tires, TJ Rubicon springs, Mopar Deep Trans Pan and Cooler
Army Vet and proud of it! Have you served your country?
Support our Troops!! Thank You!!!
silver97tj is offline
post #6 of 29 Old 05-24-2012, 05:37 PM Thread Starter
funnyduck84
It's a new timing set and I had my machinist degree the cam
post #7 of 29 Old 05-24-2012, 07:46 PM
Curly5759
Turning the Distributor has no effect on Ignition timing on our engines. Timing is controlled by the pcm, using the Crankshaft sensor for reference.
Turning the distributor will affect Injection, since the camshaft sensor is inside. Cam sensor is used by the PCM to synchronize injection with the crankshaft sensor signals.
Curly
I start what I finish!
77 Jeep Cherokee S
97 Jeep Wrangler
Curly5759 is offline
post #8 of 29 Old 05-24-2012, 08:24 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Does it take a DRB to set that properly?...
Knuckelhead is offline
post #9 of 29 Old 05-24-2012, 09:02 PM Thread Starter
funnyduck84
what is a DRB? i dont know much about 4.0s yet. my last toy was a lifted 96 ram with a 5.2. i can tell you just about any thing you need to know about that truck
post #10 of 29 Old 05-24-2012, 09:32 PM
wushaw
Rockin jeep
wushaw's Avatar
It is a very expensive tool used by dealerships to preform certain functions on a vehicle.
wushaw is offline
post #11 of 29 Old 05-24-2012, 09:36 PM
Knuckelhead
AFSOC Retired
what is a DRB?
Diagnostic Readout Box.
The good ones that I've seen run about $6K...
post #12 of 29 Old 05-24-2012, 10:04 PM
Curly5759
I have set synch using the snap on 'brick' (MT2500) and I have used a Genysis as well.
Curly
77 Jeep Cherokee S
97 Jeep Wrangler
post #13 of 29 Old 05-24-2012, 10:35 PM
Knuckelhead
AFSOC Retired
Do those work the same as the chrysler DRB tool for this effort?...
post #14 of 29 Old 05-24-2012, 10:50 PM
Curly5759
All you need is to see is the synch on the Datastream. Some scanners don't show it even though they have datastream. Don't know why that is.
If it does show up, you can set the synch while watching the scanner. Sort of like adjusting dwell on a GM V8 (showing my age.)
Curly
77 Jeep Cherokee S
97 Jeep Wrangler
post #15 of 29 Old 05-24-2012, 11:03 PM
Knuckelhead
AFSOC Retired
Curly
You're not overly old.
How about setting the 3rd brush on a generator?...
Help with timing and timing mark johnboy68 YJ Wrangler Technical Forum 2 01-25-2012 03:11 PM
2.5 Timing chain/cam timing issue csock YJ Wrangler Technical Forum 6 06-14-2011 08:58 PM
Timing help! Replaced timing chain now I can't get the timing right. yjcrawlr YJ Wrangler Technical Forum 29 04-09-2010 08:36 AM
Rebuilt 2.5 ?? YJames90 YJ Wrangler Technical Forum 11 07-05-2008 08:57 AM
New or Rebuilt 4.0 06 Unlimited YJ Wrangler Technical Forum 6 09-20-2006 02:22 PM
