HELP: Rear Vibes after SYE - JeepForum.com
post #1 of 12 Old 02-07-2012, 02:35 PM Thread Starter
tjsmith63
I Recently installed a 2" BDS lift, rebuilt transmission & transfer case, new clutch, and now a SYE and CV Drive Shaft from Tom Woods.
I installed the new SYE and CV because I was gettng the terrible rear vibes in second gear after installing the lift.
Now the new Tom Wood's Super Duty Tail Shaft Conversion kit is installed and the pinion is lined up one degree below the DS angle and I am still getting slight vibes at 70mph and over. I called Tom Woods and their people are extremely helpful and take time to go over everything in detail. They think it is probably a faulty CV ball or out of ballance DS so I am going to send it back to them.
It appears that the vibes have damaged the pinion seal as well as I can see diff fluid coming from the pinion.
I need advice on what all I should do to the rear pinion while I send my DS back to Tom Woods. I am running the Dana 35 it has 120k miles on it, and I get the howl when I take my foot off the gas at high speeds.
Any advice will help. Bearings, Seals, which bearings are best, what am I missing, etc.
Thanks for the help!
tjsmith63 is offline
post #2 of 12 Old 02-07-2012, 02:57 PM
scot68
Since you plan to go up to a 33" tire (your profile) and the fact you lifted the Jeep I assume you intend to wheel it. I would not put any money into the excising Dana 35. Think about stepping up to an Ford 8.8 or a Dana 44.
scot68 is offline
post #3 of 12 Old 02-07-2012, 03:46 PM
greene69
I don't think that would fix a death wooble, but a great mod
It's better to be dead and cool than alive and uncool.
Nothing like a permanent reminder of a temporary feeling. I have a few.
4.0 auto, 8.8 rear with detroit locker, 4.10's and 33x 12.50's
greene69 is offline
post #4 of 12 Old 02-07-2012, 05:58 PM
TJ-chopper
SYE has nothing to do with D/W, you have a problem up front, CASTER, TRACK BAR, TOE IN, TRE's, BALL JOINTS, check everything UP FRONT FOR D/W.
1997 TJ 4.0, Automatic with a 4" Zone lift and BDS adjustable control arms, AA transfercase shifter relocator bracket, Real Flat fender, custom front bumper with Stinger and 8000 lb winch. custom rear bumper with swingout tire carrier, Viking soft top, 4.10 gears, SYE and Tatton DS , Goodyear Dura Trac 33x12.50-15 and still working on it.
TJ-chopper is offline
post #5 of 12 Old 02-07-2012, 10:01 PM Thread Starter
tjsmith63
I muse be using D/W to describe the wrong thing. I had terrible rear drive line vibes that would shake the entire rear end. That is now gone with SYE just getting small vibes at about 70MPH.
post #6 of 12 Old 02-07-2012, 11:17 PM
jon1371usmc
Try it at 0* and if that doesn't cure it then check thé vibes at 2-3* and see if that corrected the problem.
jon1371usmc is offline
post #7 of 12 Old 02-07-2012, 11:28 PM
stottman
The general consensus on a sye kit is put the pinion angle 2* below the tc output shaft, I didn't see in ur profile if u have adj. uca but i'm assuming u do if u set it at 1* below.
2000 Tj with 4" lift and and 33"s, she's a work in progress got some other perfomance mods as well.
F350 King Ranch Turbo Diesel on 35's
stottman is offline
post #8 of 12 Old 02-08-2012, 08:44 AM Thread Starter
tjsmith63
I set it at 1* below using cam bolts, as I expected...they did not hold the axel in place. I am going to purchase upper adjustable control arms to set it that way. Any suggestions on which ones to get? I am looking at the BDS adjustable with flix joints to keep the contril arms the same manufacturer as the lift. Does anyone have complaints about these control arms? I am also looking at the JKS control arms?
What are everyone's thoughts on rear upper control arms?
post #9 of 12 Old 02-08-2012, 09:30 AM
Imped
Imped's Avatar
Yep, cam bolts won't do the job. Take a look at Savvy Offroad for control arms.
OlllllllO
IndyORV
Imped is offline
post #10 of 12 Old 02-08-2012, 11:06 AM
stottman
Yeah it pretty much required to at least use adj. uca's. I haven' heard anythin bad about BDS but I hear alot of good about JKS and savvy.
stottman is offline
post #11 of 12 Old 02-11-2012, 09:06 AM Thread Starter
tjsmith63
Purchased the Rubicon Express UCAs. Should be in Tuesday. Thanks for thelp.
post #12 of 12 Old 02-11-2012, 09:15 AM
GringoLoco
GringoLoco's Avatar
I used the Rubicon Express UCAs when I did my SYE a few years ago, no problems with them at all.
YELLOW Jeep Club Member #5606
13 mpg - edit: 12 mpg
No hi-lift on the hood (yet)
Odd noises
Still can't get it to take off from a treadmill....
GringoLoco is offline
drive shaft , pinion , sye , Tom Woods , vibrations
Vibes in the rear jeepinjohn72 TJ Wrangler Technical Forum 8 11-03-2010 08:15 AM
bad vibes from rear end j_shattler YJ Wrangler Technical Forum 6 10-05-2009 04:45 PM
Adjustable rear LCA to get rid of vibes? daveshan TJ Wrangler Technical Forum 12 03-25-2007 10:33 PM
SYE CV Install Rear end Vibes xeon YJ Wrangler Technical Forum 7 02-16-2005 07:16 PM
Rear vibes after sye Muddeprived TJ Wrangler Technical Forum 13 02-02-2005 02:43 PM
